390 Carb tuning, timing help
Old Jan 26, 2002 | 12:55 AM
phaffy12's Avatar
phaffy12
I recently rebuilt a 390, +.030, RPM manifold, crane energizer cam. I've got the idle RPM set, but when I set the distributor things start going bad. If I get it to accelerate without any hesitating, it'll stumble all over itself when I put the pedal to the floor from idle. When I get it to spin the tires without effort, the darn thing hesitates and backfires under normal low RPM acceleration/cruising. Any leads on this problem?
Old Jan 26, 2002 | 01:40 AM
BB's Avatar
BB
How long did your carb. sit while the engine was being rebuilt? They don't like to dry out and get wet again. Sounds like accelerator shot is weak. Start your timing at 10BTDC and go up from there.
Old Jan 26, 2002 | 08:49 AM
gtex's Avatar
gtex
I'm having similar problems, and I installed a new Ed Performer Carb. So, in my case, I don't suspect the carb. I went with a MSD billet dizzy, just to simplify the timing adjustments. That vacuum advance seems like voodoo. If I get anywhere near the 12 degrees reccomended at Idle, it runs like crap. With a real bog just off idle. If I crank the timimg up at idle, the idle RPM goes up (I compensate with backing out the idle set screw on the carb to get around 700 RPM in drive), and the bog just off idle get's better. Unfortunately, that would put my 3000 rpm advance timing advance too high with the old vacuum advance dizzy. I can change the stop bushings in the MSD dizzy to limit the advance and I seem to have found a decent combination. It's running reasonably well.
However, I'm starting to think that my real problem, is that I did not do a precise job of setting the degree for the cam when I installed it. I just got the alignment marks in the ballpark and off I went.
FE gurus: Are these symptons one might see if the cam to crank timing was off a couple of degrees?
Thanks,
Greg
Old Jan 26, 2002 | 04:59 PM
phaffy12's Avatar
phaffy12
I have a hard time believing that its the accelerator pump, b/c I bought the carb brand new. Its a Holley 750 with vacuum secondaries. The only thing i've messed with on it is the idle mixture screws and the fast idle screw to adjust the RPMs. I also lightened up the vacuum secondary spring and that seemed to help a little, but its the second lightest spring Holley sells. The accelerator pump is definitely doing its job, in my opinion. Don't they sell a pump with more flow? Should I try that next, or how about jet size? When it comes to jets, squirters, and accelerator pumps; i'm still low on the learning curve.
Old Jan 27, 2002 | 05:48 PM
flyboy2610's Avatar
flyboy2610
Try checking out these posts on this forum: Holley Carb Question 23Jan02, and Carb hesitation 18Jan02. Maybe they will help.
Old Jan 28, 2002 | 03:18 PM
fordguy76's Avatar
fordguy76
what does BTDC stand for i know its something top dead center right? i only 16 help
Old Jan 30, 2002 | 10:56 AM
unioncreek's Avatar
unioncreek
BTDC stands for Before Top Dead Center.
bob
Old Jan 30, 2002 | 03:48 PM
mblack's Avatar
mblack
[updated:LAST EDITED ON 30-Jan-02 AT 04:50 PM (EST)]I'm building a 390 right now too, and though I can't afford to change to a new 4bbl & manifold yet, I hope to soon.
I am considering a 500 cfm carb because I think it'll have a quicker throtle response and get rid of that big hesitation off idle that you guys are having. I saw a calculation once that told what cfm to use for a particular CID and RPM. I plugged in 4k for RPM cuss that's all I'll ever do. It had a big variable for something like "engine efficiency" with "race" engines being very efficient and stock engines being maybe 75%. Anyway with the LOWEST efficiency it came out something like 515 CFM for a 390.
Can you gurus out there tell me if this is right, or am I stupid?
This may not have anything to do with what's going on whith you guys but I just thought I'd stir the pot a little ;^)
Mike
Old Jan 30, 2002 | 04:50 PM
BB's Avatar
BB
You're right on, the 500cfm is the one to use. See this post:
https://www.ford-trucks.com/dcforum/DCForumID7/627.html
Old Jan 30, 2002 | 07:20 PM
jowilker's Avatar
jowilker
fosgate3
21
Sep 25, 2020 06:50 PM
Classicdriver
65
Feb 14, 2017 08:45 PM
mattjensen
15
Oct 10, 2011 12:00 PM
loki993
Jan 21, 2011 09:38 PM
Henryf250
13
Sep 24, 2003 07:32 PM
