G-Tech Pro.....
Old Sep 30, 2007 | 09:33 PM
KyleG's Avatar
KyleG
Question G-Tech Pro.....
HI, i bought one of those G-tech pro SS performance meters for my 86' f-250 with a 6.9 IDI, and when i try to calibrate it, it does'nt work. It just plugs in to the cigerette lighter and it reads the electrical current through system. It says i have a faint RPM signal...I don't know if anyone has tried using one of these before, but it works fine in all my other vehicles, except my diesel. I figure its just cause of the 24 volt system, but i cant seem to get it. It doesn't say anything in the manual about it cant work in a car or truck with a diesel engine.....can anyone give some tips?
Thanks
Old Sep 30, 2007 | 09:35 PM
KyleG's Avatar
KyleG
By the way if u were wondering, it also makes its measurements by the g-forces made by the vehicle....it's pretty cool.
Old Sep 30, 2007 | 09:39 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Your electrical system is 12 volts in an 86.
Not sure what it would see in a diesel electrical system to sense RPM.
I could see picking up the spark discharge in a gasser.
This problem will probably require a call to G tech tech support.
Old Oct 1, 2007 | 02:40 PM
KyleG's Avatar
KyleG
its is 12 volt even though it has 2 batteries?
Old Oct 1, 2007 | 03:34 PM
David85's Avatar
David85
They are wired in parallel for more cranking amps and to run the glow plugs, everything electrical in these trucks runs off of 12v.
Old Oct 1, 2007 | 06:54 PM
George D.'s Avatar
George D.
Keep us updated if you find a way to make it work I was thinking of getting one. Thanks
