3speed ID
It's a 70 F100, had an FE of some sort, converted to floor shift. It has the top plate with two shift levers on the main case, and the one for reverse further back on the case. The thing is so crapped up right now I can't get any part numbers off it. I am hoping to get this pulled out in the next few days so I can get it id'ed properly.
What other years does this tranny fit?
That 3 speed was very good in the day. So good, GM bought them from Ford and that was the 3 gear in many a GM unit.
Some info here on the 3 gear:
http://www.davidkeetoploaders.com/3speedidchart.htm
and the OD
http://www.davidkeetoploaders.com/imposters.htm
and again the OD is the first featured here.
http://www.motivegear.com/tech_info/...nny_guide.html
I'd look for a Mazda 5 speed if you can deal with a juice clutch. Or a ZF if you like.
Good luck.
The 303 trans only has two shift levers.
The 3 speed with 4th gear as overdrive came out around 78 in trucks with 302 or 300i6.
What kind of shifter is on it?
