Door latch adjustment?.....
Old Sep 30, 2007 | 09:31 AM
kuch73's Avatar
kuch73
The passenger door rattles when I drive and am wondering if there is a way to adjust the latch to tighten it up, or is this a problem from old weather strips? Thanks
Old Sep 30, 2007 | 10:01 AM
merlynr's Avatar
merlynr
You can usually adjust the striker plate on the body of truck. Usually takes one of those screwdrivers that you hit with a hammer(forgot name) to loosen that center screw. It's either a phillips or torx head. Set it in just a little and test. Worn weatherstripping can also contribute to this.
Old Sep 30, 2007 | 10:59 AM
psquare7575's Avatar
psquare7575
Check if the plastic sleeve is around the door striker bolt.
Old Sep 30, 2007 | 11:23 AM
masterbeavis's Avatar
masterbeavis
X2 on the plastic sleeve. If the weather stripping is worn, you will get whistling, but the latch should be firm around the post, and wont rattle assuming its still good. If you decide to adjust the post, make sure you mark it before you move it, so you have a point of reference.
Old Sep 30, 2007 | 12:20 PM
Mil1ion's Avatar
Mil1ion
An Impact Driver
Old Oct 1, 2007 | 11:08 AM
kuch73's Avatar
kuch73
Actually there is no plastic around the striker, thats the part that stick out of the door SILL right? Not on the door. It's just a round rod sticking out of the aft door sill. I'll have to check the yards for one of these. Thanks for the replies
Old Oct 1, 2007 | 11:32 AM
76supercab2's Avatar
76supercab2
You might be able to find a new striker post in the "HELP" section of a good autoparts store.
Old Oct 1, 2007 | 12:18 PM
psquare7575
http://cgi.ebay.com/ebaymotors/73-79...spagenameZWDVW
Old Oct 1, 2007 | 12:20 PM
Mil1ion's Avatar
Mil1ion
That would be the door Jamb....... not door sill.
Old Oct 1, 2007 | 04:37 PM
ken selvy's Avatar
ken selvy
Kragen auto $9 dollars , just bought 2 and fixed problem .
Old Oct 1, 2007 | 05:03 PM
76supercab2
I thought that Ebay ad was WAY overpriced.
Old Oct 1, 2007 | 05:59 PM
psquare7575
I posted it for the picture only, lol. That's an insane price.
pwjackson42
Apr 10, 2014 06:11 AM
lilrobo
Aug 25, 2013 11:53 AM
coondog41
Aug 31, 2011 10:39 AM
Larry NCKS
Mar 16, 2009 01:32 PM
ghall
Jul 18, 2007 10:14 PM
