P-pump
Old Sep 29, 2007 | 10:00 PM
PerkinsDiesel's Avatar
PerkinsDiesel
P-pump
I was just wondering if there is anyway to take a 7.3 IDI and put a p7100 on it rather then the lazy injector pump........Maybe change the heads to direct injection and build up the internals for those that will turn the p-pump up, alot of work but.........I'm just wondering if it can actually be done.
Old Sep 30, 2007 | 08:05 AM
Dave Sponaugle's Avatar
Dave Sponaugle
PerkinsDiesel,
Welcome to FTE and the IDI diesel forum.
Converting an IDI to direct injection would require a good bit of machine work to the head.
Old Oct 1, 2007 | 09:30 AM
j-redsjeep's Avatar
j-redsjeep
if you are talking an inline injection pump, i am fairly sure you would be talking a custom intake also because of the pump length and some machine work to get it to interact with our timing gear.
i dont think it would be anywhere near easy to convert to direct injection. to sink the injectors deep enough you will be going into the water jacket IIRC.
i think the week point will start to be keeping the heads on there.
there are some high performance possibilities like a dps or moose pump to run with the cummins boys.
Old Oct 1, 2007 | 09:09 PM
PerkinsDiesel
High performance studs for the heads would keep it in good shape....I've asked some diesel mechanics and they have told me it could be done wit a moderate diff. level.......I just want to see an old mechanical 7.3 out-do the new computerized powerstrokes ......Hope someone tries it
Old Oct 1, 2007 | 10:51 PM
Dave Sponaugle
You could cut a large hole in the precup cap which would let the fuel squirt right into the cylinder.
But the result is very hard cold starts.
Anything below 20 degrees and you probably need another vehicle, it probably will not start even if it is plugged in.
Old Oct 2, 2007 | 01:16 AM
somedude's Avatar
somedude
if you got the tools to make those mods it would be easier to build your own
engine from scratch
Old Oct 2, 2007 | 08:11 PM
PerkinsDiesel
I'm just asking is it possible? Do you think the 7.3 inner parts could handle having a turned up(way up) p-pump?(really just kinda throwing out the idea for some real gearhead to do it)
Old Oct 4, 2007 | 09:13 PM
Dave Sponaugle
The stock IP, if it is in good shape can put more fuel to the engine than it can burn.
Even running way more boost than a stock engine can stand, I can still black out the car behind me.
More fuel would just be a waste of fuel, and that much fuel would probably drop the performance.
TheTowingCowboy
General Diesel Discussion
46
Dec 30, 2012 09:06 PM
TheTowingCowboy
Apr 8, 2012 09:16 AM
strokin'_tatsch
Aug 3, 2009 06:55 AM
Moulder
Jan 22, 2007 04:11 PM
