Brake bleeding secrets . . .
Old Sep 29, 2007 | 07:37 PM
handsomerob's Avatar
handsomerob
Question Brake bleeding secrets . . .
I bled my rear brakes again and there was still a lot of air in them, I must have pumped the the pedal 100+ times to clear the air out of the rear right line. I was told 20 - 30 pumps would do.
I did the left next, The thing was after I bled them they felt the same way they did before I bled them.
is there something I'm missing?
I was also told there is an ABS that might need bleeding?
is this a seperate piece? and if so where is it located and how do I bleed it?
Old Sep 29, 2007 | 08:03 PM
jroehl's Avatar
jroehl
Bleed ALL your brakes(RR, LR, RF,LF), then if that doesn't work, look into your master cylinder.
Jason
Old Sep 29, 2007 | 08:07 PM
handsomerob
The bleed screws on the front calipers are siezed and I don't want to break them off . . .
Old Sep 30, 2007 | 12:51 AM
mebe2k's Avatar
mebe2k
i always use a hand vacuum pump/w bottle to bleed my brakes.. always works great.. less mess
i had a similar problem with the front calipers on my old 86 bronco..rounded one of the bleeder screws off.. and the driver's side would NOT budge..finally gave up and replaced both front calipers..
If there is air in your front brake lines then you will still have a spongy pedal..even after bleeding the rears
and if it is still spongy after bleeding ALL wheels, replace the master cylinder. it might have an internal leak...
Old Sep 30, 2007 | 05:38 AM
jroehl's Avatar
jroehl
What he said. ^^^ If you don't bleed the fronts, you will always have a spongy pedal (if that's where the air is, and it could be).
Jason
Old Sep 30, 2007 | 08:07 AM
big red c222's Avatar
big red c222
Obvious not the best thing to do, but you could bleed it where the brake line connects to the caliper if that will loosen. It sounds like you need a master cylinder. When I do my brakes it usually only takes about 4-5 pumps to get the air out
Old Sep 30, 2007 | 09:14 AM
JLDickmon's Avatar
JLDickmon
'bout the only option you have is a couple of regurgitated units from the parts store...
check your hoses, too.
if they're cracked, they might be ballooning
you might wanna pick up a 12'er when the beer store opens too... you might be at this a couple hrs...
Old Sep 30, 2007 | 09:37 AM
radialarm's Avatar
radialarm
Looking at the age of your truck, you would be better off replacing wheel cyls, calipers, M/C, and rubber brake hoses. The brakes are not an area where you want to get too cheap . Do it right and it will last for years. So if you spend two or three hundred bucks now and they last four or five years that's not much over time cost wise.
JL! I was looking over your profile, and we're not too much different. I like shootin up stuff, fishin, huntin, and draggin things around with my truck. I live in a house too!
Old Sep 30, 2007 | 11:28 AM
radialarm's Avatar
radialarm
Jl! I think you will like this.
www.nfatoys.com/tsmg/
Old Sep 30, 2007 | 04:02 PM
handsomerob
Does my truck have one of these? and if so, where would I find it?
Old Sep 30, 2007 | 04:05 PM
quicklook2's Avatar
quicklook2
that is the rabs.
follow the brake line from master cyl. and you will find it on the frame rail by drivers feet.
you do have a manual, right?
Old Sep 30, 2007 | 04:20 PM
handsomerob
Yes, yes I do have a manual, it's my bible, just sometimes it's very hard to follow. my rabs light is still on so I was going to try and bleed the Rabs next . . .
Old Sep 30, 2007 | 05:43 PM
JLDickmon's Avatar
JLDickmon
here ya go, Bro...
http://www.youtube.com/watch?v=WIZpCLvXsoM
Old Oct 1, 2007 | 10:13 AM
big red c222
What is that RABS. I assume it's part of the anti lock brakes.
Old Oct 1, 2007 | 10:24 AM
quicklook2's Avatar
quicklook2
rear antilock brake system
