Sponsored by: Auxito
Error code PO401 ?
Old Sep 29, 2007 | 08:16 AM
MrWillys's Avatar
MrWillys
Error code PO401 ?
My daughters 97 4.6 with 135,000 miles pulled a po401 code last night. I was going to check for carbon buildup first and then look at replacing the DPFE. I was wondering if anyone out there has had a similar problem?
<img src="Http://www.scotthansen.net/images/po401dpfe.gif">
Old Sep 29, 2007 | 08:33 AM
mdpitt's Avatar
mdpitt
I had the same code and replaced hose going into tht DPFE, it was cracked
Old Sep 29, 2007 | 06:17 PM
Wilber15's Avatar
Wilber15
Connect a vacuum pump to the EGR valve while the engine is running and pull a vacuum. if the truck bogs out and wants to die, the egr is working fine. if thats the case, examine the hoses to the dpfe sensor and if they look alright, odds are it's the dpfe sensor. known problem with more then just the f-150's.
Old Oct 1, 2007 | 06:30 AM
MrWillys's Avatar
MrWillys
I replaced the DPFE on Saturday. It cost $121 at my friendly Ford dealer. The code came back on Sunday. I guess I'll research the EGR and its piping. The hoses to the DPFE looked good, so i'm assuming it's in the EGR / throttlebody area. Anyone else suffered this?
Old Oct 1, 2007 | 06:52 AM
Joe Finn's Avatar
Joe Finn
I think you need to pull the throttle body and clean the two ports. Very common for these to clog with carbon.
Old Oct 1, 2007 | 09:33 AM
streethealer's Avatar
streethealer
My EGR ports on the upper intake were completely clogged. I was going to replace the DPFE sensor but I dont drive the truck that much and it only has 75000 miles on it.It only took about an hour to completely do the job and it was well worth it. 500 miles later and no more CEL.Everything that I could see in the intake was completely clean and carbon free. Please check these ports prior to spending $100 on a new sensor.
Old Oct 2, 2007 | 03:36 PM
NETJLR's Avatar
NETJLR
I had the same issue,,, I replaced the EGR and the DPFE sensor...
problem solved... My DPFE was'nt $121.00 though...
I think the EGR and the DFPE were about $125.00 together though
try www.rockauto.com for ford parts...you can get these two parts
factory motorcraft for ALOT cheaper than a dealer...
Good luck!
Old Oct 6, 2007 | 07:53 PM
MrWillys's Avatar
MrWillys
Well, Today I pulled what I believe is call the upper intake, and zowie Batman you guys were right. The two little EGR ports where completly clogged with carbon. Cost a few bucks for gaskets and I'm pretty confindent it won't come on again for awhile.
Thanks to all who responded. If I hadn't been lazy I could have saved $126. Atleast I'll know what to expect if I ever get highn mileage on my 01.
stevekantercool
Feb 18, 2017 03:47 AM
aeford66
Dec 8, 2015 12:25 AM
robjs111
1978 - 1996 Big Bronco
Oct 16, 2014 11:37 AM
2oo1 4x4
1997 - 2003 F150
May 15, 2014 08:05 PM
Stephanie Miller
Sep 19, 2013 09:58 PM
