Whitish smoke?
Old Sep 27, 2007 | 05:39 PM
7.3LSuperDuty's Avatar
7.3LSuperDuty
Whitish smoke?
When my dad was backing up my truck and trailer (4,000 lbs) in our driveway I saw some white smoke soming out the pipe. It was just a little, actually just enough to notice it.... I have a MBRP 4" and AFE stage 2 intake. I hope nothings wrong with my truck, can anybody help...
Thanks
Old Sep 27, 2007 | 06:22 PM
ron's power stroke's Avatar
ron's power stroke
was the temps out side cold and motor cold at that time?? did he wait for the wait to start light to go out before starting???
Old Sep 28, 2007 | 06:54 AM
7.3LSuperDuty
It was all warmed up, we were coming from work...
Old Sep 28, 2007 | 10:06 AM
61 uni's Avatar
61 uni
White smoke when cold is pretty much normal(leaky injector, 1 or more bad glow plugs) White smoke while hot is could be caused by water in oil. Is the oil cooler leaking?
Old Sep 28, 2007 | 05:54 PM
forumsearcher's Avatar
forumsearcher
I just fixed a white smoke problem by simply draining the fuel bowl. Might be worth a try. Other suggestions that were made to me were to check the Intercooler piping for excessive oil, as you may be passing oil from the turbo. Another oil culprit could be the CCV.
My worst fears were bad injector o-rings or a head gasket, but I think these are rare.
fordtruck661
Jun 25, 2012 09:08 AM
rkbutz55
Jan 14, 2011 01:13 AM
Justinbel4
Aug 20, 2010 01:25 PM
monke151
Aug 22, 2008 11:11 AM
qtrmile
May 19, 2007 08:16 PM
