The old rough idle problem
Old Sep 27, 2007 | 04:51 PM
haulingboat's Avatar
haulingboat
I have read ten pages of rough idle threads in the search engine and can't seem to find a remedy. There are lots of suggestions but I can't find where anyone has posted a solution.
Here are my symptoms. Motor runs fine. At a stop light I notice a reverberation thru the truck. The tach does not move. The motor does not die. i just have this vibration. No smoke. No loss of power. It does it in drive, park and neutral. I recently changed the motor oil. It started after that. Today I changed the tranny fluid and screen/filter. No change.
What do you think?
Thanks.
Old Sep 27, 2007 | 05:39 PM
guitarpicr's Avatar
guitarpicr
Could it be some bad diesel ? Did you gas up at same place you usually gas up?
Old Sep 27, 2007 | 07:56 PM
Budkole's Avatar
Budkole
What type of motor oil did you use? I recently "tonite" had the same thing happen. To nite i changed my oil usung delo 400 le. Big mistake! My truck hates the stuff. So immediately change the oil again using motorcraft 15-40 powerstroke oil. Now all is well. I will never use delo 400 LE again.
Old Sep 27, 2007 | 08:03 PM
Mr. Bob's Avatar
Mr. Bob
Is it a vibration through the truck??? I know that my 4" down pipe was " just touching" one of my tranny cross member bolts and it made all kids of racket....
Old Sep 27, 2007 | 08:09 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Hmmmm. I have used Rotella religiously since 02 in my truck. In April I changed it to Delo for some Molybdenum or whatever it is called for cleaning in the injectors. I am on my second change of Delo and no real problems to speak of. Dyno and drag strip #s were good there too.
I am not saying that the oil cannot be a problem, I am saying it is OK in my rig.
Old Sep 27, 2007 | 08:16 PM
Budkole's Avatar
Budkole
What are you using, Delo 400 or Delo 400 LE?
I too have used the delo 400 before without any probs, but that delo 400 LE (low emissions) stuff was no good for my truck.
Old Sep 27, 2007 | 09:19 PM
c00nhunterjoe's Avatar
c00nhunterjoe
i have the 400 le in my rig to experiment an dnoticed the imediate drop in performance and mileage, i am going back to the mobil delvac, much better, and in my opinion the delvac is better then the rottela as far as longevity. not saying rotella is bad, i have run both in my truck but i like the delvac better
Old Sep 27, 2007 | 10:19 PM
JoeTrotter's Avatar
JoeTrotter
I'm with Mr. Bob - sounds like exhaust to me. Maybe just coincidence about the oil change? Maybe just now noticed it? I know my 5 exhaust does exactly what you are describing. If you idle up a bit, does it go away?
Old Sep 28, 2007 | 12:02 PM
haulingboat
I used Delo 400LE. I have used Delo in the past, not sure if it is LE though. The vibration does go away when I accelerate or click into the high idle mod on my tuner. Which part of the exhaust should I be looking at? I had it installed over a year ago. Think it would be showing up now?
Old Sep 28, 2007 | 01:27 PM
Budkole's Avatar
Budkole
Maybe your problem is different, but mine was the Delo 400 LE! Like i said, as soon as i got rid of it, truck ran perfectly! I would hate for you to change your oil (because of me) and it didnt help, but then again, what if it does help...tuff call.
Old Sep 28, 2007 | 01:50 PM
haulingboat
Next time around I will use Mobil 1 and see if it changes. Thanks for the suggestion!
Old Sep 28, 2007 | 10:14 PM
JoeTrotter's Avatar
JoeTrotter
Having it installed a year ago would suggest something other than the exhaust, I'd think, but your problem still sounds identical to mine - mine was rattling against the heat shields, and when I would idle up a bit, and the motor smoothes out, it would go away. Mine wasn't a constant thing, the rattling would kind of surge, for lack of a better word. Rattle rattle rattle.....rattle rattle rattle...rattle rattle well you get the idea.
Maybe one of your hangers moved or loosened?
Old Oct 16, 2007 | 11:53 AM
MR5x5's Avatar
MR5x5
Just for kicks, unplug your ICP and see if the idle smooths out.
Old Oct 16, 2007 | 01:21 PM
WonderDonkey's Avatar
WonderDonkey
I have part of my 4" touching a shock, it causes some of the same noises.
HolyHandGrenade
25
Jan 26, 2013 07:59 AM
ErikLydick
May 5, 2010 04:21 PM
Keith Smith
Dec 28, 2006 09:28 PM
seanandnik
Jul 27, 2006 05:36 PM
whatthetruck
Sep 10, 2005 12:12 PM
