Trucks still sick
Old Sep 27, 2007 | 04:40 PM
powerstroked162's Avatar
powerstroked162
Trucks still sick
Well after a couple hours of work we got a new 17* hpop installed along with a new IPR and the truck still wont fire. It cranks but it wont fire. What could it be?
On a side note, my knock is no longer present
Cowboy Steve
Old Sep 27, 2007 | 04:50 PM
glasseater's Avatar
glasseater
hydrolocked?? isn't that what it's called??
Old Sep 27, 2007 | 04:56 PM
powerstroked162
Thats a gasser disease, never seen it in a diesel.
Cowboy Steve
Old Sep 27, 2007 | 05:01 PM
jboard's Avatar
jboard
Make sure the IPR electrical connection is on tight and the wires arent broke. It might just take a little time to get the air out. Check all the fuses. Is there any smoke from the exhaust at all while cranking?
------------Jeremy
Old Sep 27, 2007 | 05:05 PM
glasseater's Avatar
glasseater
Cowboy Steve
i'm talking abuot with injector instals lol
Old Sep 27, 2007 | 05:10 PM
powerstroked162
Jboard, how long did you crank on the truck before it fired up?
Cowboy Steve
Old Sep 27, 2007 | 05:14 PM
powerstroked162
Could it be the CPS?
Cowboy Steve
Old Sep 27, 2007 | 05:24 PM
1997F-350's Avatar
1997F-350
tach moving while cranking?
Old Sep 27, 2007 | 05:45 PM
c00nhunterjoe's Avatar
c00nhunterjoe
i'm still lost on the part that it has no more knock but it still doesnt run? how can you tell if it doesnt run?
how long have you been cranking since the new pump install? can take a while to bleed air and fire on oil
Old Sep 27, 2007 | 05:49 PM
wreckit72's Avatar
wreckit72
Did you fill the the HPOP with oil?
Old Sep 27, 2007 | 06:14 PM
Blankie's Avatar
Blankie
I had same problem after replacing IDM and UVCH. Tried for a couple of days no luck. Charged Batteries overnight cleaned cables truck fired. Only thing I can think of is Batteries were not hot enough to run starter and electronics at the same time. Good luck.
Old Sep 27, 2007 | 07:01 PM
tubzz's Avatar
tubzz
Cowboy Steve
it can and will happen just as fast on a diesel if not faster,
did you check you hpop level? if you just did injectors it will take up to 1/2 hour sometimes to start. if your battery are just a little low it wont start either.it will crank and sound fine but wont start.been thier done that
Old Sep 27, 2007 | 07:35 PM
jboard's Avatar
jboard
I never changed my pump but when I put new orings on my IPR and installed the HPX it took about 10 min to start. If all else fails(not recommended but...) disconnect the glowplug relay crank and give it a shot of WD40 could give it enough RPM to bring everything up to pressure.
-----------Jeremy
Old Sep 27, 2007 | 07:41 PM
c00nhunterjoe
nah, just keep a charger on the batts while cranking and make sure you dont overheat the starter
Old Sep 27, 2007 | 07:42 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
If you have an HPX line pull it off and pull the fuse for the IDM. Then crank it until you get oil out of both head rails. PUt it all back together and it should spin right up.
