Erractic idle
Old Sep 27, 2007 | 01:36 PM
skipper12's Avatar
skipper12
Erractic idle
just recently my 00 2.5 LT. idles up high after i take it out of gear into neutral,one day i had to shut it down it was idling so high almost full throttle.doesn't do it all the time just every now and then.Could the TPS be going bad?
Old Sep 27, 2007 | 09:54 PM
blue beast's Avatar
blue beast
You should try searching this has been covered many times!! Clean your Idle air bypass!! If it is gunked up it will cause idle problems.
Old Sep 27, 2007 | 11:56 PM
Peter94's Avatar
Peter94
Ditto on the IAC. Clean or R&R.
