Sponsored by: Real Truck
Bed Panel Replacement
Old Sep 27, 2007 | 12:12 PM
uliman's Avatar
uliman
I have a 2001 F350 that has quite a few dents in the center portion of the bed. I have looked at my shop manual (CD), the Haynes manual, every reference to "bed" in this forum and tried to locate schematics for the bed through a Google image search all without answering my question:
Can just the center panel(s) of the bed be replaced?
It looks like they can be; the bed is not a one-piece unit.
Additionally, Ford list a part (#8C3Z9911215A) with a retail
price of $402.85 which is referred to as a bed panel sub-assembly.
Unfortunately, I am unable to locate a picture of this part so I
cannot confirm whether this is what I am looking for.
All of the posts here seem to indicate that removal of the bed bolts allows the bed to be removed. I just want to remove the center portion of the bed without taking the bed itself off.
Anyone here have any experience with this situtation? It is greatly appreciated. I want to Line-X my bed but want to make sure that the bed itself is in better shape than it is now. Thank you.
Old Sep 27, 2007 | 12:17 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
I'm sure it's all welded together.
You'd probably need a body shop to do it for you, unless you're really REALLY good with a MIG welder and other "body stuff"...
It might be cheaper to find another complete bed without any dents and have it painted to match.
Old Sep 27, 2007 | 01:02 PM
rbaker6336's Avatar
rbaker6336
all the bed panel are welded together,the front panel is replacable but the bed has to come off to do it
the panels can be torch welded
Old Sep 27, 2007 | 01:36 PM
aldridgec's Avatar
aldridgec
You won't be able to replace the bottom of the bed without removing it. It is what holds the bed up! The outer bed panels weld to the inner bed panels and the front panel. THe side and front weld to the bottom. The bottom is welded to the cross members. You can do it, it is very time consuming and you need a spot weld drill and good mig machine and good welder to do it right. It usually pays 12 hours to do each outer side panel on the typical pickup, so that might give you an idea of the labor involved.
The dealer can provide you with an exploded parts view of the bed parts.
What color is your truck? I got a brand new take off bed for my truck factory matching paint for around $1500. Well worth it.
Old Sep 27, 2007 | 02:23 PM
rbaker6336's Avatar
rbaker6336
By stating center portion, not sure if you are talking about floor panel or headboard
at one time you could buy a layover floor section that could be layed over and plug welded from the bottom
if a body shop were to have to much work you would be better to find a take off bed
Old Sep 27, 2007 | 02:48 PM
uliman's Avatar
uliman
Thank you for the quick replies gentlemen. The answer is what I did not want to hear but I believe it to be correct. It did not make sense that the center floor panel(s) could be removed and simply replaced. I will either have to purchase a take-off bed (mine is white but I do live in Las Vegas!) or just forget the Line-X and go with a heavy-duty mat for the time being until I can find a bed here locally. Thanks again for the input.
Old Sep 27, 2007 | 06:01 PM
aldridgec's Avatar
aldridgec
White is so easy to find. It might be better to get a new bed.
Old Sep 27, 2007 | 06:37 PM
miker67's Avatar
miker67
Call a place that sells utility or service bodies. Those places normally have takeoff beds for reasonable prices and they are almost always white. Here in louisiana, new take-off beds are around $1000.00 to $1200.00 and they don't even have a scratch on them.
Old Sep 27, 2007 | 07:19 PM
uliman's Avatar
uliman
Thanks, I have already located a brand new dually (mine is the DRW model) in Canton, California (not to far away from Las Vegas) bed in white no less that is starting out on Ebay (with no reserve) of $850. I am already contemplating the swap; will probably need at least two assistants from what I have read here.
Old Sep 27, 2007 | 08:53 PM
aldridgec's Avatar
aldridgec
you need 3 plus you. been there done that.
Also, couldn't you swap the fenders over to the new bed? I haven't looked at one in a while, but know the fenders are seperate parts. That would open up the possibilities.
Old Sep 27, 2007 | 09:11 PM
krewat's Avatar
krewat
Even the fenders on my '74 highboy were welded onto the rest of the bed
Old Sep 28, 2007 | 08:05 AM
aldridgec's Avatar
aldridgec
The dually fenders.
