I have a 64 that is 5 on 5.5 and want to put some mustang rims that are 5 on 4.5. I have seen ones on ebay, does any have or know if an 1.5" spacer with adapter will be too much or too little? thanks
Well they are actually off a new v6, I got them for free. I just need something to roll to the Turkey Rod Run in November. They will not be permanent, I will get some cobras or bullits maybe. I have a set of Dodge
wheels that were about the same size and the right bolt pattern, when I tried them on, the tire was hitting the frame on the top, and the rim hit the hub in the front.
So did they change the pattern of the new mustang?
If they did I will just get new rims, but do you think the 1.5" spacer will work to run Cobra Rs maybe?
