performance mods for 391?
Old Mar 12, 2002 | 11:07 PM
whd507's Avatar
whd507
I am upgrading the points to electronic, gapping the plugs to .045, and possibly splitting the exhaust system to duals with 4' long truck mufflers (its in a bus, and currently has 30+ ft of straight pipe)
the stock holley has a governor on it, but it seems to work just fine. ( I might try my AFB on it just to see what happens)
this fall I was considering a mild cam,(if an FE cam will work), and timing chain set, any other ideas?
holley pro-jector 650 cfm throttle body setup, might be feasable also...
Old Mar 13, 2002 | 06:29 PM
FEina52F1's Avatar
FEina52F1
Use FE heads and manifolds to help breathing,
(Stick a turbo on it as is)
An FE cam will work in an FT but check the lift doesnt bind the HD valve train.
Old Mar 19, 2002 | 11:33 PM
whd507's Avatar
whd507
I might install a mild cam if it will fit, anybody have the stock specs?
will an FE timing chain set fit? will 390 Pistons work (pin size the same?)
I dont want to change heads, as it would be easier to just use a 390, but 8.5 to one pistons, and a mild cam seems like it would wake it up a little. destined to be a motorhome, need to get up hills once in a while.
391/clark 5-sp/6.14 axle (soon to be 5.83)9.00x20 tires (someday to be 10.0x22.5)
Old Mar 19, 2002 | 11:57 PM
FEina52F1's Avatar
FEina52F1
>stock specs?
only top gear and chain
>size the same?)
yes
>use a 390,
it is the port size that will have the most effect
Old Mar 20, 2002 | 12:03 AM
FEina52F1's Avatar
FEina52F1
wwbenner
13
Nov 22, 2013 06:40 PM
CRUNKED77FORD
Jul 14, 2013 11:57 PM
LIF150
Jan 10, 2012 05:23 PM
redsuperduty
Jun 7, 2009 09:14 PM
ford truck oldboy460
35
Jan 11, 2009 03:44 PM
