Modular V10 (6.8l)
V10 cat?
Old Sep 26, 2007 | 06:35 PM
big10's Avatar
big10
Question V10 cat?
Which catalytic converters are good for the V10? All the ones I can find are for 5.9L engines and smaller. What difference does that make?
Old Sep 26, 2007 | 09:53 PM
Sport45's Avatar
Sport45
What's wrong with the one that came with it?
Old Sep 27, 2007 | 04:52 AM
big10's Avatar
big10
Its plugged up and I dont wanna fork over the outragous price of the oem cat. I do however want to stay legal. Im not sure but I think if its rated for a smaller engine it will still work but wont be able to hold back as much.
Old Sep 27, 2007 | 11:13 AM
Sport45's Avatar
Sport45
Are you sure it's plugged up? That's unusual since leaded gas hasn't been around since long before these engines were made. The stock cat has a lower restriction than most aftermarket "high flow" cats.
There are some converters for 6.8's here
Or you might want to use two smaller converters, one on each bank.
Old Sep 29, 2007 | 05:49 PM
dkf's Avatar
dkf
First off, are you in a "Sniffer Test State" such as California or any state that adopted Cali emissions? If you are the best bet would be an OE replacement or aftermarket direct repleacement.
I have a little Dynatech 3" cat on my truck. It isn't rated for displacement or anything like that. You can see through the thing very easily so I figured capacity or flow isn't really a concern for me. Local emissions for me is just a visual check, just have to have a CAT don't matter what kind. I have been running the dynatech cat for over a year with no problems.
Converter size is usually determined by displacement. More Ci = Bigger larger Capacity Cat Less Ci = Smaller less Capacity Cat.
Search for cats on Summit Racings site, you will find all different capacity converters for different cubic inch engines.
Old Sep 29, 2007 | 08:15 PM
big10's Avatar
big10
Thanks for the tips. Im not really sure what exactly they do here but a mechanic said most cars can still pass here unless they are new and the engine light is on. This is in NY. I used to live in cali and you cant do ***** out there to any part of the vehicle.
V10KLZZ71S
Modular V10 (6.8l)
Dec 12, 2002 12:27 AM
Jetfixr
Nov 11, 2002 10:30 PM
billb
Nov 26, 2001 10:18 AM
460v10
Aug 3, 2001 07:29 PM
V10 MAN
Dec 27, 1999 09:48 AM
