Modular V10 (6.8l)
PCM location?
Old Sep 28, 2007 | 09:37 PM
droesse4's Avatar
droesse4
Red face PCM location?
I am trying to find the PCM on my '02 f350. I am planning on buying a tuner from Troyer performance and need the code off of it. On their web site it says there should be a big sticker on it, but I must be blind. Does anyone have a pic of where it is?
Old Sep 29, 2007 | 04:37 AM
Monsta's Avatar
Monsta
Sit. Stay.
It is to the left of the parking brake assembly and a bit behind it. Right inline with the fender.
Old Sep 29, 2007 | 09:02 AM
Fredvon4's Avatar
Fredvon4
Before going through all the hassel of getting to the hard to get to PCM look inside of the drivers door frame for a 3/4"x3/4" or 1"X1" sized sticker with a code like IGW0 or CQE6 (can be any one of about 25 "codes") usually 3 letters and a number
My sticker was on the door frame in front and up by the mirror area, my buddie's was on the Truck inner door fame by the top hinge
Some times the sticker is on or IN the PCM, and sometimes on the firewall inside or outside "near" the PCM...
Don't you love assembly line workers that giggle screwing with the owner or the Flat Rate Technician? Butt-heads!
Old Sep 29, 2007 | 04:16 PM
droesse4's Avatar
droesse4
Thanks guys I'll look again when I get home from work.
Old Sep 29, 2007 | 07:33 PM
pops_91710's Avatar
pops_91710
Mine was on the drivers door up near the hinge on my 2003 5.4 SD. But not on my 03 V10. I had to get a mirror and pop the hood and take it off the tag on the PCM.
Old Sep 29, 2007 | 09:17 PM
droesse4's Avatar
droesse4
Well, there is no stickers anywhere in the door frame. I am still a little confused as to what the pcm lookes like and where it is located.
By "parking brake assembly" do you mean power brake assembly? If so, you must be refering to the driver side fender, am I correct?
Old Sep 29, 2007 | 09:33 PM
pops_91710's Avatar
pops_91710
Look at my Gallery Photos. It shows you where.
https://www.ford-trucks.com/user_gal...=32358&width=0
If you look closely you can see the white label on the left side of the black box. That is the PCM code label. If you have no mirror, get one or remove it with a 10mm socket like I expalin in the gallery.
It comes out thru the Parking Brake assembly on the inside but I found my label on both my trucks on the outside. You have to go under the hood the remove the wiring harness ***'y or that puppy ain't going nowhere!
Old Sep 29, 2007 | 10:37 PM
droesse4's Avatar
droesse4
I GOT IT!! But, wow what a pain that was! Thank you, I don"t think I would have found that on my own. I have a really small mirror with a flexable handle that I could get into the side of the harness in between the plug and the fender that I could barely get at the look the sticker. Once again thank you! Once I install my Y-pipe and tuner I will post what I think about hte mods.
