Fuel cups
Old Sep 27, 2007 | 05:12 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Pulling the lines doesn't clear the heads. It will will push it all the way out within a few seconds.
Why would your fuel system be holding static pressure? Mine drops to 0 within a minute of shutting off the truck.
Old Sep 27, 2007 | 05:16 PM
Action4478's Avatar
Action4478
Originally Posted by cookie88
No. You remove the fuel feed lines at the filter bowl. Whichever head has the bad cup(s) will bubble out of the corrosponding fuel line. It will at least let you isolate which head has the bad cup(s) before you even remove the valve cover.
Thanks......
Old Sep 27, 2007 | 06:08 PM
99SevenPoint3's Avatar
99SevenPoint3
Does anyone have the part numbers from either Ford or International for the fuel Cups and O-rings and what are the prices you guys have heard ..from what i understand should be a lil less expensive from international ... Thanxs in advance guys!
Old Sep 28, 2007 | 09:36 AM
99SevenPoint3
Anyone...?
Old Sep 28, 2007 | 10:28 AM
largefries's Avatar
largefries
In Alldata it says you have to drain the fuel rails, so that is what I followed. Maybe that is not necessary. But, if you don't and pressure drops to 0, won't fuel run out of the lines anyway? Just trying to get this straight incase I have to do it again.
I can post part numbers tonight if I can find the reciepts. And yes International is about half to a quater the price of ford.
Old Sep 28, 2007 | 05:47 PM
cookie88's Avatar
cookie88
FTE Emeritus
I don't know what an alldata is, but there is no prep work necessary. I simply disconnect the two output lines from the filter can, and apply 20 or so PSI to the coolant degas bottle.
If there are bad injector cups it is obvious almost instantly as the remaining fuel and air *spurts* out of the end of the line connected to the head with the bad cup.
Old Oct 1, 2007 | 10:44 AM
largefries's Avatar
largefries
I tried it the other way. I took the lines off and pressurized, with air, to the psi of the fuel system. I had the thermostat out and coolant filled right to the top. The coolant didn't move. Not sure why air pressure works one way and not the other? But, if I have to do it again I'll try it your way.
Alldata is a computer Haynes manual, basically.
99sevenpoint3, I can't find the part #'s, looked all weekend, sorry.
Old Oct 7, 2007 | 03:10 PM
99SevenPoint3
Thanks large fries ive recently made a post to see if i can come up with the part numbers this maybe the cause of my issue/problem ive been having with my truck i dont plan on replacing all of the cups or orings jus the ones that need changing ...
