Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
ignition key won't turn
Old Sep 25, 2007 | 11:48 PM
frozentexan's Avatar
frozentexan
Question ignition key won't turn
My girlfriend has an '01 Escape. I pulled it into the garage to change a front turn signal bulb. Sadly, the ignition key doesn't seem willing to turn now and the car is stuck in the garage. Thought the steering might be in a bind so turned the steering wheel hard in both directions while attempting to turn the key, no luck. Are ignition lock cylinders common failures on these vehicles? If so, is it the sort of thing a locksmith can deal with? Is there something else (PATS? other stuff?) I should be looking at? Thanks for the help!
Old Sep 29, 2007 | 08:13 PM
5_labsownus's Avatar
5_labsownus
My 02 Escape had the problem like yours. I found that if the tilt steering column is in the “full down” position that the key would not turn. All I needed to do is raise the column up the slightest bit and the key would turn. It never has stuck again.
Old Sep 30, 2007 | 10:20 AM
aquanaut20's Avatar
aquanaut20
There is a brake interlock on the key barrel, check the connection under the dash.
Old Oct 7, 2007 | 11:14 AM
frozentexan
Thanks, I owe an update. After much repositioning and wiggling of the wheel, WD-40, and alternating swearing and prayer, I called a mobile locksmith. New lock cylinder (matched to our existing keys) and key, reprogramming of the new key and our existing two done in my garage so no towing hassle - $200. The old keys were pretty well worn, the car does have 154 mi on it now. The locksmith was able to confirm that this is a very common failure.
Toplait
Jun 17, 2015 09:03 PM
TexFinn
19
Feb 8, 2015 09:09 PM
jayro88
Apr 18, 2014 06:43 AM
love2truck
Sep 5, 2013 09:05 PM
cobrarep
Aug 3, 2008 01:13 PM
