vacuum leak
Old Sep 25, 2007 | 09:11 PM
JWH2's Avatar
JWH2
vacuum leak
My 86 F250 460 keeps burning the carb. gasket at the passenger side rear corner just above the EGR valve creating a bad vacuum leak. Does anyone have an idea where all that heat is coming from? I know there is alot of heat involved with the EGR but to Burn the gasket like that? Any info would be great
Old Sep 27, 2007 | 12:38 AM
gearhead351's Avatar
gearhead351
Since nobody seems to be answering you ill take a stab at it. The EGR (engine gas return). The exhaust from the heads onto the top of your intake and back into the motor. Your exhaust I would imagine is nothing short of 200 degrees. You might try some heat tape or making a heat shielf with some sheet metal. (bend by hand). I would probably try making a heat shield of some sort. Or ask your auto parts store if there is a high temp gasket made.
Old Sep 27, 2007 | 01:26 AM
jimbo beam's Avatar
jimbo beam
Simply fix is to remove the EGR completely and throw it across the yard, thats what I did. Otherwise a tougher gasket, or heat tape may help.
Off topic, I always thought EGR stood for Exhaust Gas Recirculation
Old Sep 27, 2007 | 01:28 PM
gearhead351
o well doesnt matter we know what we are talking about!
Old Sep 27, 2007 | 01:41 PM
Franklin2's Avatar
Franklin2
Usually a gasket will not hold because it's not supported correctly. So I would look at the area where it's burning out, and see if it's eaten away or damaged. If the gasket is not pinched in there tight, it's not going to hold.
Old Sep 27, 2007 | 07:51 PM
JWH2's Avatar
JWH2
Hey thanks for the replies and yes I know what egr stands for, but the problem is the truck runs at a fairly regular 200 deg.,installed a mech temp.gauge and that corner gets hot enough to partially melt the grommet on the gasket,I was just wondering if anybody else had run across this.Somebody said back pressure can cause ths? Motor has 20,000 on factory rebulid??
Old Sep 27, 2007 | 08:36 PM
Sport45's Avatar
Sport45
I'd check Franklin2's suggestion and make sure the gasket is properly clamped. A loose fit could result in an exhaust leak under the EGR plate. That will heat the plate much more than the normal low EGR flow rate.
Old Sep 28, 2007 | 07:36 AM
scottddove's Avatar
scottddove
had the same problem on my 86 460 and what I discovered was the two surfaces were no longer flat anymore and would not make a good seal. The problem is the heat as you have said and the metal deteriating away in that thin area. had to change intake manifolds to fix it. I suggest getting rid of all the smog stuff and going with a aftermarket intake. Mine runs like a top now with no leaks. hope his helps scott.
Old Sep 28, 2007 | 02:21 PM
JWH2's Avatar
JWH2
Thanks Scott, I'm goinging to change the intake, and the spacer, as for the smog stuff I live in California and thats not really an option to tear it all off.Thanks to all that responded Jeff.
Old Sep 28, 2007 | 05:07 PM
Piffery1's Avatar
Piffery1
You may be using the wrong gasket. My '83 F350 w/460 uses a thin gray gasket (as OEM) with no problem. I've never tried the thick brown gasket (the one with grommets) that was also included in the carburetor rebuild kit.
Old Oct 4, 2007 | 01:01 AM
ceanz's Avatar
ceanz
I had the same problem on my '86 460, just replaced gasket today. I had the spacer machined to flatten/smooth it out, i really hope it holds. dont wanna replace manifold. Sounds like this is a cronic problem w/these trucks.
jazztone
29
Jul 30, 2014 11:25 PM
dawhits1
Feb 11, 2014 03:14 PM
jaywall
Feb 18, 2011 01:48 PM
Ford F1Fool
Apr 2, 2008 07:36 PM
JWH2
Sep 28, 2007 07:32 PM
