General Automotive Discussion
Head studs
Old Sep 25, 2007 | 07:36 AM
MisterCMK's Avatar
MisterCMK
Head studs
Anyone care to explain the benefit of head studs over head bolts? Thanks.
Old Sep 25, 2007 | 08:41 AM
ghunt's Avatar
ghunt
Studs torque more evenly than bolts because you're only turning the nut at the top of the stud, rather than turning an entire bolt...so you get a more accurate torque reading on your torque wrench and there's less likely to be a lot of variation between the studs.
As a result of that I believe studs are also said to have more clamping power.
Old Sep 25, 2007 | 09:26 AM
spikedog's Avatar
spikedog
ghunt is right on.
Old Sep 25, 2007 | 09:28 AM
spikedog's Avatar
spikedog
YOu can bottom out the studs too, whereas the bolts will always have to be unable to reach the bottom of the threaded hole in the block.
03powerstrokefl
Dec 16, 2013 02:38 PM
1989f250IDI
Aug 6, 2012 03:23 PM
catherf-350
Jul 25, 2012 04:54 PM
6lpowerstrokesrj
Jul 15, 2008 01:26 AM
fordf3502007
Apr 12, 2008 02:29 AM
