390 FE Heads
Old Apr 5, 2002 | 11:02 PM
ruthless's Avatar
ruthless
390 FE Heads
The 390 I have has a two barrel manifold on it. Whats the deal on my heads ? Are the intake ports going to be too small for the new Performer RPM manifold I just puchased? Should I be looking to change heads, and if so, which heads will do the motor justice?
Old Apr 6, 2002 | 08:50 AM
dinosaurfan's Avatar
dinosaurfan
390 FE Heads
RuthlessMike, your heads probably will be fine. Ford made two basic sizes that you are likely to see. The early large port (2.35 tall) and the later small port (1.95 tall). There are many varaitions of both. What is the casting # on the heads you have ? DF
Old Apr 6, 2002 | 10:27 AM
ruthless's Avatar
ruthless
390 FE Heads
I don't know. Where do I look?
Old Apr 6, 2002 | 02:45 PM
ruthless's Avatar
ruthless
390 FE Heads
Ok I found it. they are C8AEH
Old Apr 7, 2002 | 11:20 AM
karlsd's Avatar
karlsd
390 FE Heads
Those are good heads. They are the later design, and have fairly small (67-69 cc) combustion chambers. They'll work just fine with the Ebock intake.
Old Apr 7, 2002 | 03:50 PM
ruthless's Avatar
ruthless
390 FE Heads
Cool. Anything I can do to them to make them better? springs? rockers? different valves or angle cut?
Old Apr 8, 2002 | 07:57 AM
karljay's Avatar
karljay
390 FE Heads
I'd start with some porting work. If you don't have your headers yet, get them so that you can match them up.
Take the heads apart and bolt on the headers and feel the inside or use some wax paper to draw the ports in relation to the bolt holes. Then match up the ports to the headers. I rounded the edges on my headers and oblonged the bolt holes for a proper match. Just make sure there is no edge for the gas to hit against (have the header port larger than the heat port) Mark the headers so you can align them when installing, I use orange nail paint for mine.
Grind out the humps in the roof of the exhaust and blend in the bowl areas about 2" in from the valve. Grind down the valve guide and unshroud the valves in the combustion chambers. remove any casting flaws.
Get hardened exhaust seats and a good 3 angle valve job AFTER you've done the porting (just in case you miss and hit the sealing area)
Match the intake ports too or at least make the head a bit bigger so that the air/fuel doesn't hit a sharp edge.
I assume your running headers, the FE really likes them, the stock exhaust sucks bad.
Old Apr 8, 2002 | 08:14 AM
karlsd's Avatar
karlsd
390 FE Heads
'73 250
Jun 18, 2008 11:28 AM
marilyn
Aug 23, 2006 02:42 PM
Purely Ford
Apr 7, 2004 01:19 AM
proeliator
Jun 4, 2002 08:44 PM
6t8
May 10, 2002 09:31 PM
