Cracked head?
Old Sep 24, 2007 | 05:14 PM
smclaughlin's Avatar
smclaughlin
Cracked head?
hey .. imnot sure if im dealing with a cracked head or a freeze plug issue.. its a 94 F150 .302 . leaking water.. ... whats my best bet?
Old Sep 24, 2007 | 06:13 PM
pastorattheridge's Avatar
pastorattheridge
Where is it leaking at? Is it gushing out or just seeping when the motor warms up? I am not sure where the freez plugs are on your motor but I would get a list of all of them and at least you could be sure you checked them all before thinking the worst. I baught a truck one time that we thought had a cracke block but turned out to be a rusted out freez plug. the water gushed out all the time but the whole in it was large. fixed it and the motor ran fine. good luck hope its just a plug
Old Sep 24, 2007 | 06:40 PM
17fordguy's Avatar
17fordguy
Is Wter In The Oil Wil Look Milky
Old Sep 24, 2007 | 06:50 PM
pfogle's Avatar
pfogle
Where is it leaking? Does it overheat? Common places to look, the weep hole in the bottom of the water pump, front of the heads where the lower intake manifold meets the heads, and where the water pump mounts to the timing chain cover. If you need to wrap the distributor in a plastic bag and go nuts on the front of the engine at the car wash.
Old Sep 24, 2007 | 08:52 PM
mstrelectrician's Avatar
mstrelectrician
pressure test the cooling system to find your leak, If you don't have one some auto parts store's rent tools.
4604x4
May 14, 2010 08:13 AM
Struts 'N' Stuff
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Mar 24, 2004 04:59 PM
AbadDriver
Bronco II
Jan 30, 2003 01:31 PM
texasbob
Jun 23, 2002 03:33 PM
