cracked cylinder heads
There was a thread on this a couple weeks back and if I remember right there is an allowable tolerance for the cracks. I want to say it was something like as long as the cracks do not enter the valve seat they were OK. But I don't remember the exact thread or who that information came from.
I was told that both heads if milled, were cracked so bad that they would fall to pieces.
It's hard to think that this truck ran decent w/o using any fluids or smoking and was just doing some preventive work and egr delete & now have an added core charge of $2000 because my heads are cracked
FYI--I just did a little checking on Ed the Parts guy's site. NEW HEADS-- $1011.17 each plus $250 core charge.
You can get completely rebuilt heads for $500 each... from "Cylinder Head International" in Texas. New would be best if you can afford the expense...
When I had my heads inspected, they had hair line cracks in several places between the glow plug port and valve seat. I suspect its more common than you think. What i would really like to know is if it even matters that there are hairline cracks? Of course the guy at the machine shop tells you it matters because he wants more business but in reality I don't know.
That means the premium for new heads is $1,200 a pair if you got it from the great Partsguy...
Work out the labor cost to put it in (even if you do it yourself), and the other costs (coolant, gaskets, etc).
Hardly worthwhile using remans... which is a cesspool of bad parts if you got it from a poor vendor.
Let someone else mess with it.
