Brake shimmy
Old Sep 24, 2007 | 04:59 PM
taxman1's Avatar
taxman1
Brake shimmy
1995 Explorer experienced shimmy only when braking, especially at high speeds. Thought it was a warped rotor. Had all 4 rotors and the brake pads replaced. Still experience the shimmy. Any ideas what could be causing this?
Old Sep 24, 2007 | 07:51 PM
99f350sd's Avatar
99f350sd
Sounds fishey. Maybe you got a bad rotor. Or you have a bad front tire. Move the tires to the rear and try it then.
Dick
Old Sep 24, 2007 | 07:59 PM
taxman1's Avatar
taxman1
I agree it does sound odd but it did get brand new pads and rotors all the way around. Tires have been rotated and balanced and still, the vibration/shimmy exists. I suppose it could be a bad rotor but that would be unususal, since these were brand new Powerslot rotors.
Thanks
Old Sep 24, 2007 | 08:02 PM
99f350sd's Avatar
99f350sd
Maybe one of the rotors is sitting on crap and not flat. Slightly bent axle?
Old Sep 24, 2007 | 08:09 PM
taxman1's Avatar
taxman1
Never thought of that.
It appears from all that I have read that, with the symptoms I have described, it will almost always be related to a rotor, correct? That was my original inclination but after having them all replaced with brand new rotors, I began to wonder if there was something else that might likely be the problem.
championbuilder
Feb 13, 2012 11:30 AM
DanK5
1997 - 2003 F150
Aug 4, 2011 10:43 PM
FordMan35
Apr 6, 2010 01:11 AM
deerdude
2004 - 2008 F150
Nov 22, 2009 05:49 PM
Bob Wilkinson
Sep 16, 1999 03:50 PM
