Aerostar Ford Aerostar
Windstar Odometer Correction
Old Sep 23, 2007 | 10:14 PM
frederic's Avatar
frederic
95 Windstar, digital cluster.
Is there anyway for the DIY mechanic to correct the mileage of a cluster? I swapped one recently and the original cluster had 75k on it and the junkyard replacement has about 140k. I'd like to reset this obviously if possible.
If I have to reset it to zero, then pulse it to 75K I can pulse it no problem.
Anyone have any ideas, links, or suggestions?
Thanks!
Old Sep 24, 2007 | 09:02 AM
krankshaft's Avatar
krankshaft
There are many places online where you can send it to get it reprogrammed unfortunately they seem to want to shroud the details in "black magic".
This is done with a programmer the wires leaving it are soldered to the odometer at 6 points. The programmer reprograms to EEPROM replacing the mileage data.
Old Sep 24, 2007 | 09:50 AM
frederic's Avatar
frederic
Well if that's all it is I can probably reverse engineer it assuming the eeprom is marked with it's correct designation and not resurfaced to hide its type/model/brand.
Making a simple programmer or adapting one I own is cake, just need to figure out which eeprom was used.
Thanks for the tip!
frederic
40
Dec 28, 2021 02:54 AM
ryzl30
New Member Introductions
Jan 27, 2008 10:24 AM
smackme
Aerostar
Feb 21, 2007 01:09 AM
belovedkj
Electrical Systems/Wiring
Sep 7, 2005 10:15 PM
