I'm not saying it could'nt happen, but it does seem very odd to me. The engine has overspeed protection perimeters built within the ECM, and under that condition would de-fuel, throw a code and a check engine light. It would'nt just go back to normal without a trace of the problem.
I understand what you are saying but, I was also looking at the guage when it happend.
Maybe the guage was not accurate.
All I know is the gauges went crazy the truck wanted to take off like I was putting the petal to the floor and no check engine light. The service advisor asked me if the check engine light went on as well. I told him no engine light he still said he wanted to do the update on the computer ASAP. ( do you thnk they know something we don't know or don't want us to know? )
FYI... electronic fly-by-wire accelerator has been in use on PSD since the 03 six-oh was introduce. So it should'nt IMO cause this problem, unless it has something to do with the DPF high idle strategy?
Its been in use allot longer than that.My buddy 97 powerstrike has it.
I stand corrected.
It appears that Ford, as well as many other mfg, has used it on several model years ago.
My 2001 X5 has it, but I thought that it was just another one of their cutting edge technology at that time.
The powerstroke series diesels all had throttle by wire since 1994, when the powerstroke first came out. The older none computer diesels were from 1983-1993.5, and had accelleration fuel flow controled completely by direct cable linkage, and a mechanical RPM governor (3300-3700 rpm).
No I was not referring to you (at least I don't think so). I was referring to the post where the guy had his truck run away with him and could not stop. Had cops chasing him .....
I would also like to hear more about this incident.
There must be a different incident than the two on this thread because I did not have a problem turning the key off and the cops did not get involved.
Diesels have a peculiarity in that they can "Run Away". This usually occurs when the crankcase has been overfilled. The engine oil gets sucked past the rings and is ignited in the cylinders causing the engine to run at maximum speed. No amount of governor actuation will stop it. I saw this occur on a Cummins diesel generator once. They had to block the air intake with large rag to stop it. I dont know it the 6.4 is capable of such nastyness
The old 6.9 diesel has a way of burning large amounts of oil if the CDR valve gets clogged, but not once have I ever heard of a 6.9 running away except for an incorrectly assembled injector pump.
I can't imagine that much oil getting past the rings of a brand new engine either.
Now if the turbo oil seal blow out, soposedly that can also cause the a runaway condition. But I think there would be some smoke to indicate all the extra oil going out the tailpipe.
You are correct, in a run away condition you would see alot of smoke and you would have to cut the air off to shut the engine down
