391 FT
Old Apr 8, 2002 | 11:24 AM
truckmaniac's Avatar
truckmaniac
391 FT
Hey everyone,
I've got a question for anyone. I just bought a 391 FT, casting D4TE-1, at an auction for $5.00, I'm in the tear down now. What kind of performance parts are there for this? I just gonna build it to resale or put into a 4x4 later. I like the stronger bottom-end it has.
Mainly right now I'm looking into the induction and vavle-train for it. Just to see what's available.
Any help would be great,
truckmaniac
Old Apr 8, 2002 | 02:27 PM
karlsd's Avatar
karlsd
391 FT
Anything that works on a FE 352, 360, 390, etc., should work on it just fine. Ideally, you should replace the heads and intake with FE parts, which will perform much better in light duty applications than the FT ones.
Old Apr 8, 2002 | 02:56 PM
6 8's Avatar
6 8
391 FT
[updated:LAST EDITED ON 08-Apr-02 AT 03:57 PM (EST)]IIRC the distributors are different,
the 391's oil pump drive was larger.
391's has forged steel cranks too...
Bates
Old Apr 16, 2002 | 10:59 PM
TKONO's Avatar
TKONO
391 FT
will a 391 crank fit in a 352,360,390 block? Is the end of the crank any larger where the harmonic balancer goes? Thanks
John
Old Apr 17, 2002 | 12:21 AM
karlsd's Avatar
karlsd
391 FT
The 391 FT crank is not interchangeable with the FE crank. The snout is a larger diameter on the 391 crank. It can be turned down, however, so that it will fit in a FE block.
Old Apr 17, 2002 | 10:07 PM
TKONO's Avatar
TKONO
391 FT
hey thanks! Is that the only difference?
John
Old Apr 18, 2002 | 12:24 PM
karlsd's Avatar
karlsd
391 FT
WentzMetalWorks
24
Mar 9, 2025 08:36 PM
Kev1180
Jul 1, 2015 10:08 AM
F600Logger
Large Truck
Apr 25, 2015 01:28 PM
Chris 56 f6
Large Truck
28
May 23, 2014 03:19 AM
Chris 56 f6
Oct 27, 2013 10:18 PM
