truck wiring (Prodigy brake controller)
Old Sep 23, 2007 | 09:32 PM
pf350's Avatar
pf350
my trailer brake (prodigy) lights up with 0.00 when I step on the brakes. I can't find a break in the line anywhere so is there a fuse I am missing. Just wondering if anyone else has seen this problem. I have checked my wiring diagram three times, uninstalled and reinstalled the unit. The only thing I can think of is that the brake signal is cut either befor or after the prodigy unit. Any ideas on where to check next. thanks
Old Sep 24, 2007 | 01:47 AM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Just to make it clear, is it doing this with a trailer connected and the tandem vehicles in motion?
Does the Prodigy display show anything when you operate the manual lever with the tandem vehicles at a stop?
Old Sep 24, 2007 | 06:55 AM
grafekie's Avatar
grafekie
Hehe simple answer: you have the power set to zero Use the roller-**** on the left to turn it up. Swing the lever underneith all the way and gradually turn up the power until you have enough power to slow the rig when you are driving 10-20mph.
Old Sep 25, 2007 | 07:12 PM
pf350's Avatar
pf350
vehicles connected, manual lever no response.
Old Sep 25, 2007 | 07:14 PM
pf350's Avatar
pf350
Talking
I wish I were an complete idiot sometimes so all my questions could be answered this easily . Unfortunateley I am only a partial idiot so it makes it harder for everybody.
Old Sep 25, 2007 | 08:25 PM
F350-6's Avatar
F350-6
Have you checked the pin connectors in your plug to make sure your getting good contact? Also check to make sure you're properly grounded. You can check your plug output with a simple voltmeter. If all is good there it's probably a connection or ground issue.
F2250crew
Oct 21, 2014 04:39 PM
vtx1800
2004 - 2008 F150
16
Oct 21, 2014 07:31 AM
dieselscout80
Sep 26, 2014 07:57 AM
beeser
Nov 8, 2013 05:14 PM
BlueDog
Aug 13, 2007 08:34 AM
