I have 85 Ford F250 4x4 460 4sd will not turn off. Please help?
I have changed Ign. switch. The key Ign. I do not know why it will not turn off. I can turn the key all the way back and the truck still runs. I would put it into gear and kill the motor that way and pull the negative wire off the battery and then something will click and maybe reset because i can put it back together and restart but still no turning off of the truck.
starter relay could be the cause to that problem.
sometimes the relay will keep it from dying when shut off. ford has a high reputation for either not shutting off when switching off or to try to start while nobody is in it or around it untill it kills that bat. you can try tapping the relay next to the bat and sometimes it will stop till you start again. but as soon you get it to shut off cahange it. they cost any where from 4 to 20 dollars.
now this might be the cause or you have a bad ignition switch again or something like that.
isenegger
Electrical Systems/Wiring
33
11-10-2022 05:08 PM
btduckcall
03-07-2014 07:00 PM
Duner
10-01-2012 09:48 PM
isenegger
10-26-2009 02:48 PM
kjdunn
11-21-2006 11:11 PM
