Win on Sat. work on Sun..
That's awesome man, it's amazing how you can do so well with just hybrid injectors, studs, with stock oil and just a big turbo! How about a hand for the guy who does the tuning, anyone want to guess?
You're a powerstroke legend Kevin, i tell ya. You just need more fuel.....
Dan i remember back in a vid he had some CPS problems and the truck was cutting out just like that.
Originally Posted by Kwikkordead
That's one of the best pulls I've seen you in. Nice job.
I have a question. Right at the start of the pull, (and I've seen this before) your stacks make a pop sound and the black smoke clears to about 50%.
What's that pop?
What's that pop?
Joe
Tenn it's one of the new Pro Dry filters. No oil!
Kwikk The IDM can't recharge fast enough so the pcm starts cutting pulse width. Running out of fuel.
Here are some vids from Smithton PA. Not sure if I posted the before or not.
1st hook (dropped)
2nd hook
pull off
1st hook (dropped)
2nd hook
pull off
It's defaintely an injection/electrical issue. Just the other day i was rolling some smoke in Park for some diesel buddies who said my truck can't really make that much smoke, and i mashed the pedal and got the same result. Happened a few times. I guess they just can't respond that quick?
Don't want to go Garden-hosing the fuel in the engine, bad stuff happens. Did jody live tune your truck? What size nozzles are you running? I believe a set of B-codes and a big oil setup to up the ICP will help you alot by raising IP without too much more fuel..not going overboard. What kind of ICP do you see now?
Kris the injectors are an off the shelf set of hybrids flowing 230 or so cc's of fuel. ICP never drops below 2900 and I've seen peeks at 4000. The tuning is also nothing special. No live tuning and the tunes are three years old. No matter what you do when you add more fuel to make power you will increase pressures. If not your just blowing smoke.
John the twin IDM's have been a talked about for a while. I know of nothing being usable yet.
