Regen, Sooty Pipes, and some white smoke
Originally Posted by proctow13
How much soot is acceptable? I bought my truck in May with 30 miles on it. Now at 7000 the tailpipes are black on the inside. Nothing real thick and I noticed that they turned darker over the last couple of months. I haven't thought much about it until I read this post. Any comments?
Originally Posted by bh4478
i have an 2008 f250 diesel and it goes into regen about every 18 hours and stays in the regen mode for about 20 minutes but it smokes (white smoke) like hell under the hood and even comes between the cab and bed any sugestions
thanks for the info but i cant hear any exhaust leaks and the smoke comes from the passenger side by the fire wall
It doesn't take a leak large enough to be audible to cause a huge cloud of white smoke at the leak. One evidence of a leak before the dpf are telltale soot trails. Usually, the joint between the turbo and exhaust system is great for leaks due to thermal cycling, especially if it isn't sealed well with a graphite-type seal. You could also have a leak at the exhaust manifold on the right side of the engine. You have 4 gaskets plus a joint between the manifold and turbo(s).
Countryboys6.4
6.4L Power Stroke Diesel
12-22-2013 07:50 PM
05 CO King Ranch
21
03-11-2010 08:43 AM
