When my truck reaches 95 to 100% soot level the truck initiates the regen process. The truck used to stay in active regen until the truck got down to the high-teens percentage-wise but I've noticed now the regen process quits at around 35% and then steadily starts climbing and within a few miles (all freeway driving) is back up to 45%. This is one of the main reasons I'm only getting 100 miles between regens.
Bring it back to the dealer, you should get much more than 100 miles between regen's. How much urea are you using, less than usual or more than usual. Sounds like a sensor is going bad and the regen is timing out. you should still have warranty with that. Let them pay for the repair.
DEF usage and regen frequency are not necessarily related. "Regen" is when the DPF gets clogged with soot and fuel gets injected during the exhaust stroke to burn it clean. "DEF" is injected into the SCR to reduce NOx emissions and is caused by high combustion temps, and that is what the consumer adds to the tank inside the fuel filler door. Hope this helps.
5 gallons of DEF every 6,000 is about as average as you can get. The tank is not filled from the factory and most dealers don't fill it during PDI (my guess to save money) unless you ask.
I agree you're producing too much soot for highway miles. Is boost PSI normal with a launch? It just seems like there is an air issue to be producing that much soot that quickly.
My 2011 regenerated every 100 miles give or take, last trip in it was 3 times in a 300 mile round trip with 1 or 2 stops. I took it in and they said, "the truck knows what it's doing" 200 miles later the stop safely light came on. Egt sensor failure... Traded it in on a new 2015 platinum f250 and get about 300 miles per regen same route of driving to and from work on hwy about 15-20 miles each way.
Failing EGT sensor is a good point. More believable than a failing/disabled turbo which is where my air idea came from. My truck built up a lot of soot limping it home with 0 PSI boost two years ago.
Same here. Watching the CTS soot level shows way different regen characteristics on the 2015 than what I was used to seeing on the 2012. The 2012 would always start a regen at 2.67 and burn down to 1.15 or so, but the 2015 might not start until 3.80 or then again it might be 2.20 and stop at 1.50 or burn down to 0.15. There is obviously some hardware and/or programming changes in the newer models for controlling this complex process. Always room for improvement.
I can testify from experience that if a regen starts and EGT 4 is at 1000 or above and you're at your destination, don't shut it off. Let it idle for 10-15 minutes and it will continue to burn soot. The red "R" will turn off but it still continues to burn soot until EGT 4 drops below 800 or so. Shutting the engine off sooner will stop the process immediately and you start a new regen all over again the next trip.
One more thing to consider is oil quality. Soot levels excluding a hardware failure, is a matter of driving habits and oil quality. I see most people here like Rotella. I switched from whatever was cheapest to Rotella and my regens are a lot further apart. My CTS is really a great tool for monitoring regens but a MUST for heavy towing for monitoring engine, tranny and electrical. I watch all 4 exhaust temps and it is true that after the regen cycle quits the soot keeps burning off until temps go down. Mine gets up around 1100 for the duration and usually starts at 2.66 and quits 1.30 but will settle around .98 before climbing again
Dealer most likely will do nothing without a CEL set. Even then, if they cant verify say a bad EGT sensor through testing, even though there may be a CEL code, they still wont replace. My dealer did not, anyway.
Not saying you have a bad EGT sensor, but your symptoms sound a lot like mine did before it set the CEL. Mine ended up being a bad EGT12 sensor that I ended up replacing myself because the dealer would not.
