better block
Old Apr 28, 2002 | 04:11 PM
ncargo9's Avatar
ncargo9
better block
I have 3 fe blocks to choose from on are tore down yet but one is a 353 cast 70 360, one is a 360 1973 which has ribbing along bottom of the block, and third is a 105 390 block from a 75 f150. is there a preferance on the blocks which to use?
what i am dooing is putting a 410 crank(200.00) from autozone with bearings, and building a stroker for my 71 f250 high torque low rpm motor.
Old Apr 28, 2002 | 05:03 PM
Ratsmoker's Avatar
Ratsmoker
better block
The 105 block has reinforced main webbing and more than likely, thicker cylinder walls. Are you sure autozone has a 410 crank for $200?? Have you bought it yet or did they just say they could get one.
Old Apr 28, 2002 | 06:03 PM
ncargo9's Avatar
ncargo9
better block
bouht it last night from a guy thatworks with me in the Navy, we works there part time and got thecrank for me. came fresh .010/.010
with bearings also 200.00 out the door.
Old Apr 28, 2002 | 06:05 PM
ncargo9's Avatar
ncargo9
better block
took one day to get the crank from there warehouse, and they are brnging in a set of rods this eek for the crank
Old Apr 28, 2002 | 07:07 PM
FE427TP's Avatar
FE427TP
better block
you got a very good deal and I'd see how many more you could get fresh machined with bearings you can probably sell them for 400-450 on Ebay I'd take a drill bit index and see which block can consistantly have the smallest drill bit fit between the bores through the freeze plug holes, whichever one has the smallest drill bit fit most likely has the most metal on the cylinders.
Old Apr 28, 2002 | 08:33 PM
Ratsmoker's Avatar
Ratsmoker
better block
FE427TP is right. I didn't think of that earlier. That would be the best way to tell.
Old Apr 29, 2002 | 08:00 AM
ncargo9's Avatar
ncargo9
better block
thanks guys, i just bought 2 more fe motors from alocal yard for 40.00 each complete pulled and set in truck. they are both 360'2 a 71 and a 76.
Old Apr 29, 2002 | 03:53 PM
BB's Avatar
BB
better block
TheDawnof68
23
Sep 29, 2014 07:07 PM
bigfoot22
18
May 28, 2008 01:31 AM
jlepitzki
Offroad & 4x4
Jan 20, 2007 12:32 PM
dmoore0733
23
Dec 19, 2005 04:31 PM
1985ColumbusF150
Oct 9, 2004 11:42 PM
