Question on Volt gauge.
Old Sep 21, 2007 | 10:50 PM
gtsom6's Avatar
gtsom6
96 powerstroke, 154,000. Every time I start the truck the volt gauge sits on the (N) for almost 30 seconds before it jumps up to the, I guess normal position, between the R and M. Any suggestions on what may be going on. The only issues I can think of doing this is the glow plugs, but I don't know.
Old Sep 21, 2007 | 11:51 PM
kawa's Avatar
kawa
I have a '97 PSD and thought that I had that same problem until c00nhunterjoe told me that was just the way they were made. After the engine starts it won't show a charge on the instrument for 30-45 seconds.
What threw me was that I had never noticed this quirk until I washed my engine. I thought that all hell had broke loose.
Roger
Old Sep 22, 2007 | 11:52 AM
jboard's Avatar
jboard
Its the Glowplugs...they can stay on for up to 2 minutes after the truck is started depending on how cold it is out. This keeps the engine from smoking when its cold. The draw that they take is a hefty one somewhere around 80-90 amps thats why the volt gauge stays low until they turn off. Its actually a good indicator of when to drive, its best to wait until the gauge jumps up(GP's turn off) until you drive because too much of a load on a hot GP will damage them. Plus diesels need to warm up anyway or severe engine damage can occure...especially when its very cold out. but between normal temps anything over 60-65 just wait for the GP's to turn off then drive away. below that i wait 5-10 min and extreme cold below freezing 10-15 min or so.
-----------Jeremy
Old Sep 22, 2007 | 04:25 PM
gtsom6's Avatar
gtsom6
OK, that's what I was thinking but wanted to make sure. I just had to buy 2 batteries and was thinking maybe there was an issues that killed the batteries.
Old Sep 23, 2007 | 11:36 AM
tjbeggs's Avatar
tjbeggs
The Alternator is PCM controlled and will not charge for the first 40 seconds after start up. After that its also the glow plugs. but The alt doesn't charge for the first 40 seconds
Old Sep 23, 2007 | 04:48 PM
IDMooseMan's Avatar
IDMooseMan
Good info, TJ. I wasn't aware that was happening. Rep points sent.
Old Sep 23, 2007 | 04:50 PM
IDMooseMan's Avatar
IDMooseMan
Thanks for the info, jboard. I didn't realize the GPs were staying on that long. Rep points sent to you, also.
Old Sep 23, 2007 | 06:13 PM
jboard's Avatar
jboard
Thanks always a pleasure to help.
---------Jeremy
