What controls GP on time
Old Sep 21, 2007 | 10:25 PM
zvacsource's Avatar
zvacsource
Can anybody tell me what sensor controls the amount of time the GPs stay on? And where is it?.....95 CC PSD
Old Sep 21, 2007 | 10:29 PM
c00nhunterjoe's Avatar
c00nhunterjoe
engine oil temp- located on the backside of the high pressure pump resevoir, 2 wire connector, and intake air temp sensor- located in stock airbox. the pcm takes those 2 readings and determines on-time from there, it also uses those sensors for exhaust backpressure valve activation too
Old Sep 21, 2007 | 10:35 PM
fuelman's Avatar
fuelman
What happens to gp control if you do eot mod to advance timing.Haven't done anything like this just dawned on me when you mentioned eot?
Old Sep 21, 2007 | 10:39 PM
fuelman's Avatar
fuelman
I guess after thinking about it ,it would just cycle longer because it would think its cooler outside.right?
Old Sep 21, 2007 | 10:51 PM
zvacsource's Avatar
zvacsource
Thanks, what is the mod for EOT? Somewhere in this forum it was advised to un plug the exhaust valve, is this advisable?
Old Sep 22, 2007 | 06:50 AM
Cuda_jim's Avatar
Cuda_jim
Definatly unplug the EBPV. It's supposed to aid engine warm up but causes more trouble than it's worth. The EOT mod tricks the PCM into thinking the engine oil is still cold. The PCM adds more fuel and advances the injector timing but the higher RPM's suffer.
BTW: The Barometric Pressure (BARO) Sensor controls the GP not the IAT.
The glow plug system is electronically controlled by the powertrain control module. The powertrain control module energizes the glow plugs immediately after the key is placed in the ON position and then determines how long the glow plugs will be on according to the engine oil temperature and the barometric pressure. The required time for the glow plugs to be energized decreases as the engine oil temperature and barometric pressure increase.
Old Sep 22, 2007 | 08:48 AM
c00nhunterjoe
sorry it was late, iat is soley for ebpv
Old Sep 22, 2007 | 11:41 AM
jboard's Avatar
jboard
Yes The EOT mod does mess up GP on time I did it then un-did it because the GP's would stay on same amount of time when hot as they did when cold. and I believe thats hard on them, but you could do a Switchable EOT mod where you flip a switch to gain the timing you want then turn it on after you start so the GP's turn off as normal.
---------------Jeremy
Old Sep 22, 2007 | 01:19 PM
c00nhunterjoe
or run a switch inline with the pcm signal to the relay
MarauderV8
Dec 17, 2014 01:44 PM
wasa 1500
Mar 2, 2011 05:59 PM
awhtx
Large Truck
May 21, 2010 12:00 PM
kuzco
Nov 9, 2009 08:24 AM
cocot
Jun 30, 2003 12:13 PM
