Transfer case?
Old Sep 20, 2007 | 05:32 PM
88PONY's Avatar
88PONY
Question Transfer case?
How can I tell which one my truck has? 1991 F250 5.0L 5-speed.
Thanks
Old Sep 21, 2007 | 04:13 AM
cowmilker's Avatar
cowmilker
There should be a label on the back of the t-case that will tell you.
Just grab a rag (every one I've ever looked at was all oily/dirty) climb under the truck, find the label (usually a round thing in the middle on back side of the t-case), wipe it off and read it.
Probably someone on here can tell you by year what it is, maybe they will chime in.
Old Sep 21, 2007 | 07:45 AM
handyman43358's Avatar
handyman43358
Probably a Borg Warner 1356.
Old Sep 21, 2007 | 11:36 PM
dhag911's Avatar
dhag911
i believe that it is probably the 1356 i am almost sure that is what is in my dads 90 f-250 5 speed diesel. otherwise yea look for a tag that will be connected to one of the bolts that hold the 2 halves together
Old Sep 22, 2007 | 02:36 AM
88PONY's Avatar
88PONY
ok, theres no tags, but it says borg warner 1354...could that be it?
Old Sep 22, 2007 | 03:20 AM
F150xlt's Avatar
F150xlt
For your year F series truck they used the 1345 or the 1356 transfer case.
There was two versions of the 1356. An electronic shift and a manual shift.
I think the 1354 was used on the Bronco II and Rangers.
Click here for a pic. of the different transfer cases.
http://truckparts-specialists.com/ca...ture-index.htm
Old Sep 22, 2007 | 06:16 AM
tjc transport's Avatar
tjc transport
i ain't rite
yup. 1345 case. the 4X4 shifter is in line, without any side to side movement, rite??
a 1356 case should have a sideways jog in the shift pattern to get into 4 low
Old Sep 22, 2007 | 09:37 AM
handyman43358
TJC I'm not sure... my 95 shifter with the 1356 doesn't go side to side, but you do have to push down to get it from 4 High to Nuetral... then to 4 Low. Maybe that's what you're thinking...?
Old Sep 22, 2007 | 09:47 AM
wizzard351's Avatar
wizzard351
i dont mean to hi-jack this but witch one of these newer type t-cases are the tuff ones? i know back in the 70's the 205 was hard to beat,so in 80 when ford went with all aluminum cases i just thought they all junk,but know thats all i can find
Old Sep 22, 2007 | 11:36 AM
tjc transport
i ain't rite
chad, by 95 the 1356 case went back to the inline shift pattern with push down and pull back for 4 low. the early cases used a sideways shift to the drivers side and pull back to get into 4 low.
the early 1345 case used the push down and pull back pattern.
Old Sep 22, 2007 | 07:14 PM
88PONY's Avatar
88PONY
i pull the shifter down once and it goes to 4 hi and to the left and down for 4 low. its a 91 f250
Old Sep 22, 2007 | 07:17 PM
tjc transport
i ain't rite
yup if you need to pull it down and left for 4 low it is a Borg Warner 1356. very good case.
that is the same t-case all my diesel trucks had.
and i only killed one, after 14 years of abuse with 325 h.p., the 5 speed, turbo, and no muffler exhaust
Old Sep 22, 2007 | 09:42 PM
handyman43358
Ahhh I see now. Thanks for the update TJC!
pintoches
May 27, 2026 07:13 AM
BigPapi
Oct 9, 2009 08:53 AM
starweb
Washington Chapter
Apr 5, 2009 12:39 AM
billyb
Jul 17, 2001 06:25 AM
