fuel filter light?
Old Sep 20, 2007 | 03:24 PM
f350 goatee's Avatar
f350 goatee
fuel filter light?
93 f350 turbo, when I switched tanks on the way home, the fuel filter light went on. If I switch it back, it goes off. Btw, I was on the freeway. I also show a little bit of white smoke all the time! Recently had return lines, fuel filter, and injectors changed, runs good though. Any ideas? Thanks!
Old Sep 20, 2007 | 07:02 PM
Ironman03R's Avatar
Ironman03R
Sounds like your fuel selector valve is not switching. Only other thing I can think of is you possibly have a lift pump going bad. I went through 2 filters and kept blaming "gelled" fuel before I realized mine was bad. For the $25.00 I think I'd throw one on for the piece of mind. Just my .02
Old Sep 21, 2007 | 03:47 AM
somedude's Avatar
somedude
I would guess fuel lift pump or air being sucked in at the tank selector valve or fuel lines to the tank
Old Sep 21, 2007 | 07:57 AM
PLC7.3's Avatar
PLC7.3
Fuel filter light signifies a vacuum in the filter header...... when was the last filter change.
Take the filter header Schrader valve core out and hook a hose and pressure guage to the outlet.........crank engine see what you get for pressure, should have 4-6 psi from a good lift pump.
Volume test same place hook a hose to it crank over the engine 10 seconds you should get 1/3 pint of fuel minimum or 1 pint at 675 rpm in 30 seconds... engine running
Important the fuel shutoff solenoid (FSS) wire on the IP should be disconnected if you do not want a start just cranking. Re connect FSS after test complete.
Old Sep 21, 2007 | 08:38 AM
f350 goatee
filter was changed 2 weeks ago, gonna check the lines from tanks and selector switch this weekend, maybe change the lift pump?I have a vacuum pump, if it works, I'll try and test the filter. Thanks guys, I'll keep you posted!
A/Ox4
Projects
45
Apr 15, 2013 03:45 AM
bandlgeorge
37
Nov 19, 2007 04:12 AM
f350 goatee
Oct 31, 2007 10:56 PM
flyMike
Jun 21, 2005 07:18 AM
kutze2
New Member Introductions
Aug 31, 2004 11:02 PM
