I've searched, Honest
As Black04 already stated... you only have to pull... (seems to be easier to start from the bottom)
Just be on the look-out for the metal clips and make sure they stay On the dash side. It should make the bezel a bit easier to snap back on.
After you have it off be ready to pop-off the wiring harnesses for the lighter plug, airbag deactiviation light, etc...
****Some have actually left the A/C wiring attached and just held on to the bezel or strung it out of the way. I like to remove it just seems easier to see and work around IMO.
Then you have the 4-screws holding the factory radio in....
I've go into mine probably 2-3+ times a month to change out headunits, rewire options and add-ons. I'm going into it either tonite or tomorrow for another HU swap ... so I may be able to take pics or video if necessary.
Try "+remove +bezel" (sans quotes) and specify this 2004-2008 forum.
https://www.ford-trucks.com/forums/6...and-power.html
https://www.ford-trucks.com/forums/5...004-radio.html
https://www.ford-trucks.com/forums/2...o-04-f150.html
https://www.ford-trucks.com/forums/4...5-f-150-a.html
https://www.ford-trucks.com/forums/4...l-removal.html
