99 Ranger High Idle Problem
Old Sep 20, 2007 | 08:51 AM
awad188's Avatar
awad188
I have a 99 Ranger, 3.0, automatic with a well maintained 53,000 miles that developed a high idle about 6 months ago. (1,000-1,100rpm in drive).
Tried resetting computer by removing battery cables, touching them together, etc. Dealer installed a new IAC valve, mass air flow sensor, cleaned the throttle body and checked for vacuum leaks. No change. Truck runs perfectly otherwise. Dealer agrees it's a problem, but is stumped as no codes show up. Any ideas?
Thanks. (Seems to have started with a new battery installation, but not sure.)
Old Sep 21, 2007 | 07:51 AM
tomw's Avatar
tomw
I'd check the alternator output. If you get spikes on the output, it can send weird signals through, that may confuse the ECM. I had a bad regulator (someone washed the engine compartment...) that caused the engine to die when shifted from D to N. The IAC couldn't handle the signal change quickly enough to prevent the engine stalling. I *THINK* that there was garbage on the "dc" current (hash..) that confused the ECM or was enough to mess with the signal the IAC was getting. From what I know, the IAC gets a 'buzz' that energizes the solenoid at quick enough rate to position the spool valve. It does not move to position "X" and sit there, it must be coerced by continuously sending pulses of juice. More pulses, more solenoid movement against the spring-load. Add some hash to the mix and you get a confused solenoid...or bad feedback to the ECM.
tom
Old Sep 21, 2007 | 09:22 PM
blue beast's Avatar
blue beast
Take off the intake hose at the TB and see if your butterflys are open anything more than a C-hair. If so somebody tweaked the throttle hard stop or your throttle linkage is hooked on something and not getting to the idle position!!
Old Sep 23, 2007 | 12:26 AM
JPFergy's Avatar
JPFergy
I just had the same problem with my 02 xlt 2.3l. There are 2 IAC valves and mine are vacume operated. drove me nuts for several weeks until I was changing my shocks, looked up at the engine through the splsh guard in the drivers side wheel well and saw a small crack on the underside in the bend of a vacume hose. just so happens that it was a hose that went to my #1 IAC. bought a foot of hose for .68 cents and replaced in about a minute. The problem was solved by pure luck and the truck runs great again.
Good Luck
Old Sep 23, 2007 | 09:03 AM
pawpaw's Avatar
pawpaw
Stuck open PCV valve maybe!!!!!
Old Sep 25, 2007 | 08:13 AM
awad188's Avatar
awad188
Thanks Tom. I'll try both your suggestions.
Old Sep 25, 2007 | 08:14 AM
awad188's Avatar
awad188
Thanks. I'll try it.
Old Sep 25, 2007 | 08:29 AM
Peter94's Avatar
Peter94
I would suspect a vacuum leak. do you hear any whistling at all? Check your fuel pressure regulator, they will cause a high idle. I seem to remember my 88 idling around 1k until I replaced it
Old Sep 25, 2007 | 08:39 AM
awad188's Avatar
awad188
Thanks Peter. I'll add this to my list of possible remedies. -Al
Old Sep 25, 2007 | 08:49 AM
Bear River's Avatar
Bear River
Former ******
A quick simple test for an electrical IAC valve is to unplug it. If the idle drops the problem is with the valve and/or its controls. At that point spray it with some throttle body cleaner (do not scrub it). If it improves further, the valve is sticking. Cleaning it may fix it, but if the problem did improve, but did not go away, the problem is beyond a simple cleaning. The valve will need to be replaced.
I am not familiar with vacuum actuated idle controls, but I would assume if you uses a clamp of some sort to pinch of the vacuum source and then disconnect the vaccum line from the valve, the idle should rise since deep vacuum would trigger the valve to open.
Old Sep 25, 2007 | 11:02 AM
Rockledge's Avatar
Rockledge
Good Luck
Good to hear you fixed the problem.
However, there is only one Idle Air Control (IAC) valve used on your engine, and it does not have any vacuum hoses running to it. So I suspect you are talking about something else, like maybe the DPFE sensor or an EVAP system component, something along those lines.
Old Sep 27, 2007 | 08:46 AM
awad188's Avatar
awad188
Thanks Tom. You may be on to something as the engine compartment was washed, as you mentioned. Can't tell you by who. I'll have the alt. & reg. checked. Thanks again for the input.
Old Sep 27, 2007 | 08:48 AM
awad188's Avatar
awad188
Thanks to all for input on my Ranger high idle problem. Much appreciated.
Old Sep 29, 2007 | 05:53 AM
97ranger xlt's Avatar
97ranger xlt
check pcv valve as another member also suggested.....it was the cause of my high idle problem...
