Dual Batteries
Old Oct 23, 2007 | 01:58 PM
  #31
Franklin2's Avatar
Franklin2
whats the best brand of battery isolator you can think of that would be worth purchasing for my application?
Any of them will work. All they are is a big diode mounted on a heatsink. You will have to debate if you want a good deal on someplace like ebay, or buy it locally where it might have a warranty and you could return it if it failed when you hooked it up.
Is there any sort of big fuse box i can get to eliminate the 3-4 big wires I have coming off of the battery for the aux stuff? I'd like something I could just run one big wire to, and then it distributes the power to 4-5 other wires, each one being fused.
Here's one.
http://www.crutchfield.com/App/Produ...on&i=211CBR44A
Old Oct 23, 2007 | 03:41 PM
  #32
WoomaHodal's Avatar
WoomaHodal
thats $80 though. i'm going to try and find something a bit cheaper or perhaps on ebay
Old Oct 23, 2007 | 04:07 PM
  #33
78F150XLT's Avatar
78F150XLT
if you really want for that circut splitter for ur amps and stuff, you can easily rig one up, i can send u a diagram and list the stuff to use its just if you want to spend the time doing it or how good it will work.
Ok i'll call the one alternator/starter rebuild place not far from me and se if i can scam a isolator off of them!
Old Oct 24, 2007 | 03:07 PM
  #34
Mil1ion's Avatar
Mil1ion
I have an extra 90 amp rated isolator with a 50 amp Circuit Breaker here .
Old Oct 24, 2007 | 05:46 PM
  #35
WoomaHodal's Avatar
WoomaHodal
can you email it to me?
just kidding.
Old Oct 25, 2007 | 08:11 AM
  #36
chrono4's Avatar
chrono4
One other thing that you can do cheaply to your charging system is add a few extra gounding cables. On my bronco I added a ground cable front the alternator braket to the battery, and another from the battery to the fire wall. Upgrade the charging lead from teh alternator to the battery. I used all 4 gauge amp power wire for all of this because I had a bunch of it around.
I did my batteries the cheap easy way but when it died, i still just had 3 dead batts. I wired all 3 of mine in parralel. They were all optima red tops.
Old Oct 27, 2007 | 01:03 PM
  #37
blue beast's Avatar
blue beast
Heres a cheap set up just get a starter solenoid and the wiring and it is basically
automatic one toggle switch in the cab!! http://chrisb.users.superford.org/Br..._wiring_02.JPG
Old Oct 27, 2007 | 08:52 PM
  #38
Franklin2's Avatar
Franklin2
I have never heard of an automatic toggle switch .
Old Oct 28, 2007 | 01:31 PM
  #39
WoomaHodal's Avatar
WoomaHodal
haha yeah i haven't either. i'd like to see how it works though!
mlb4966
Jul 20, 2014 10:55 AM
f2504x4man
Electrical Systems/Wiring
Dec 22, 2013 07:30 AM
86F150302
Feb 15, 2008 01:56 AM
natewoz
Feb 10, 2007 07:43 AM
yukonsly
Jan 10, 2006 06:09 PM
