glow plug relay
Old Sep 19, 2007 | 05:02 PM
Big_red78's Avatar
Big_red78
glow plug relay
Ok now weather is getting colder and she won't start. Glow plug relay clicks after wait to start light go's out. Mechanic told me that it was because it had some glow plugs out. So I just put in 8 new Motorcraft/Beru XD-9 plugs. Turned the key and started to hear a buzzing noice. Then it quit and the light went out. Relay started to click. Started just fine. So I guess my Question is "Why does the relay click after the wait to start light go's out?"
Thank you
Old Sep 19, 2007 | 09:14 PM
PLC7.3's Avatar
PLC7.3
One more time before winter..........
93/94 year info.......other than some fuses mentioned the 7.3 system 87-94 is basically the same.
GLOW PLUG CONTROL
HOW THE CIRCUIT WORKS
The Glow Plug Control circuit applies power to the Glow Plugs, which heat the combustion chambers so that the diesel engine can be started.
Glow Plug Controller
The solid-state Glow Plug Controller, attached to the top of the engine block, controls the Glow Plug pre-glow and after-glow time. It also controls the circuit’s operation by sensing engine temperature, Glow Plug voltage and after-glow voltage
from the start/run circuit.
When the Ignition Switch is turned to START or RUN, voltage from Maxi-fuse K is applied through the Glow Plug Controller to the Wait-To-Start Indicator Lamp.
The Glow Plugs heat up in zero to fifteen seconds, depending on engine coolant temperature. After the Glow Plugs heat up, the controller cycling switch opens and turns the Wait-To-Start Indicator Lamp off. The Glow Plugs are now warm enough for the engine to be started.
At the same time the Ignition Switch is turned to RUN, voltage from Maxi-fuse K is applied to the after-glow timer (located inside the Glow Plug Controller). The after-glow timer cycles the Glow Plugs for up to two minutes, depending on engine temperature. The after-glow timer then opens. The Wait-To-Start Indicator Lamp will not light during the after-glow period.
If the Ignition Switch is turned OFF, it can be turned to ON immediately, and the Glow Plug heating cycle will start again.
Diesel Start/Run
The diesel engine uses two batteries to provide extra power for starting and Glow Plug heating. Power is applied from the batteries, through heavy gauge wires, to the Starter Solenoid (located in the Starter Motor assembly). When the Wait-To-Start Indicator goes out, the Ignition Switch can be turned to START.
With the Ignition Switch in START or RUN, voltage is supplied to the Fuel Heater, Fuel Shutoff Solenoid, and the Engine Temperature Switch through Maxi-fuses K and U.
The Fuel Heater is in the Fuel Filter/Separator. It heats the diesel fuel, melting any wax that might clog the filter. The heater has an internal thermostat to turn it on as needed at 32*F.
The Fuel Shutoff Solenoid controls the flow of fuel into the injection pump. With the Ignition Switch in START or RUN, the Solenoid is energized, and fuel is allowed to flow into the injection pump. When the Ignition Switch is turned off, the solenoid is deenergized, fuel flow stops, and the engine stops running.
The Engine Temperature Switch provides voltage to the Cold Timing Advance Solenoid and the Cold Idle Solenoid. When the engine temperature is below 112°F (44°C), the Engine Temperature Switch is closed. When the Ignition Switch is turned to START or RUN, the solenoids are energized, advancing injection pump timing and engine idle, allowing the engine to run more smoothly when cold. When the engine temperature reaches 112°F (44°C), the Engine Temperature Switch opens. This deenergizes the solenoids, returning the timing and idle to normal.
Old Sep 20, 2007 | 09:29 AM
Big_red78's Avatar
Big_red78
The glow plug system is working properly. The engine starts good now. I was just wondering why after the wait to start light goes out it starts to click. The voltage gauge jumps and the lights dim while it clicks.
Old Sep 21, 2007 | 04:31 AM
somedude's Avatar
somedude
the glowplug controller is turning the glowplugs on and off to heat the perchambers to reduce emmisions on cold starts
the controller cycles the glowplugs because if you hold them on manually they will all pop at about 30 secs
Old Apr 15, 2008 | 10:12 AM
nonbill's Avatar
nonbill
Mine keeps turning on the engine light and says that 2,4,6,8 glow plugs are not working can they all go out at one time like this , on the same bank
Old Apr 15, 2008 | 10:50 AM
RCrawler's Avatar
RCrawler
It is possible that they can all fail at the same time. More than likely, you have a wiring issue in the harness going to that side.
BTW, this is the IDI 6.9, 7.3 forum. You should try posting in the 99-02 Powerstroke forum to answer your question.
Welcome to FTE
Jason
Red Sled
33
Sep 14, 2022 12:26 PM
fifty-two_f1
33
Dec 1, 2019 08:20 PM
Codeman894
Sep 28, 2017 08:59 AM
Lyle Murphy
Jan 5, 2016 06:00 AM
mcphm519
Jan 9, 2011 08:54 PM
