What HEADS to use
Old May 29, 2002 | 07:36 PM
66ford428's Avatar
66ford428
What HEADS to use
I am putting a 428 together for my 66 ford truck.
I would like to know what heads to use. I am not going to do a lot of hauling with it. I am looking for it to put out around 400+ hp. looking for a good stock heads. I found some 390 GTA heads. Does any one know about these. any sugestions I would be glad to hear THANKS!!
Old May 29, 2002 | 07:45 PM
FE427TP's Avatar
FE427TP
What HEADS to use
Cobra Jet heads would work, but every factory head is good to 400hp just depends on how streetable the cam will be
Old May 29, 2002 | 08:39 PM
proeliator's Avatar
proeliator
What HEADS to use
Those are fine heads. Just have your machine guy do some minor work on them and put in the CJ valves and you are good to go.
Old May 30, 2002 | 12:22 AM
karlsd's Avatar
karlsd
What HEADS to use
Uh, what are "390 GTA" heads? What is the casting number?
I have two sets of C8AE-H heads, one of which has just been freshly rebuilt for my 428. I've often seen them referred to as "390GT" heads, but I know they were used on lots of FEs.
Old May 30, 2002 | 06:58 AM
hotrodford_88's Avatar
hotrodford_88
What HEADS to use
Look at the exhaust ports on your heads, if you see two different sets of bolt holes, then they are the GT heads. Example, the factory 390 holes are above & below the ports, the GT heads have them diagonally as well.
I believe that's right anyway, look at a set of the Edelbrock FE heads, and you'll see what I'm talking about.....
https://www.ford-trucks.com/user_gallery/displayimage.php?&photoid=5199&width=0
If the link doesn't work, there's a picture of a set of the Edelbrock FE Heads in my gallery....
Old May 30, 2002 | 11:18 AM
karlsd's Avatar
karlsd
What HEADS to use
Ford made FE heads with at least three different exhaust manifold bolt patterns. The heads for trucks and large cars use eight bolts at the 6 and 12 o'clock positions in relation to the exhaust ports. There are also 14 and 16 bolt heads. I am not aware that the heads were significantly different internally, however -- the bolt configuration was simply a matter of packaging in smaller cars.
Are you saying that the 14 and 16 bolt heads are better performance heads than 8 bolt heads?
Old May 30, 2002 | 11:26 AM
BB's Avatar
BB
What HEADS to use
The only 16 bolt heads I am aware of are the CJ’s. The 14 bolt heads were used in the 390GT (or GTA) or just plain 390 engines used in the intermediates. Nothing special about the GT heads except for the stiffer valve springs like the CJ's.
Barry
Old May 30, 2002 | 12:14 PM
Ratsmoker's Avatar
Ratsmoker
What HEADS to use
tcobra66
13
Oct 8, 2011 12:04 AM
rodriguezfords
16
Jan 10, 2010 07:43 PM
muscletruck
Apr 12, 2009 02:13 PM
66_in_ky
42
Nov 25, 2007 11:20 AM
anotherF150
Sep 20, 2003 10:47 PM
