Intermittent starting problem
Sounds like a IAC valve problem. Next time this happens, try putting a little bit of pressure on the gas pedal to open the throttle a bit. If this helps, then the IAC is the problem. Time to replace it. Good luck!
By | 2026-06-12 11:01:55
By | 2026-06-09 11:10:08
By | 2026-06-09 10:53:36
By | 2026-06-08 18:50:34
By | 2026-06-05 12:58:01
By | 2026-06-03 09:51:16
By | 2026-06-03 15:43:58
By | 2026-06-03 11:38:36
By | 2026-05-27 16:24:34
By | 2026-05-27 16:17:28
