Clutch Help
Old Sep 19, 2007 | 06:42 AM
MikeFromShiloh's Avatar
MikeFromShiloh
Clutch Help
I found a Luk clutch kit, flywheel, pressure plate, that has been pulled from a 99 F550. Will this fit my 95 F350?
thanks for the help
MW
Old Sep 19, 2007 | 10:40 AM
61 uni's Avatar
61 uni
Flywheel might, I don't think the clutch kit will. You can buy this new from Carolinas Clutch for $540. If i pully the tranny, i'm putting new parts in. my .02
Old Sep 19, 2007 | 01:47 PM
1997F-350's Avatar
1997F-350
i dont think they are any different but i clould be wrong.
Old Sep 19, 2007 | 05:43 PM
Neal 97 250's Avatar
Neal 97 250
I would use the flywheel and get the new clutch and PP from carolina clutch.
Old Sep 19, 2007 | 11:48 PM
RubberDuck's Avatar
RubberDuck
Mike, I don't see why it wouldn't work. But if for some reason you don't think it will work, give Dan Vallance a call at www.valairinc.com . Tell him Cody from Death Row Diesel sent ya and he will hook you up for FAR less than anyone else. And the clutches kick azz. He has everything you need. You can look at the prices on line, but call him and tell him I sent ya and I promise it will be better than you ever thought on price.
Old Sep 20, 2007 | 12:04 AM
frnkln2003's Avatar
frnkln2003
I may be wrong but I think that the ZF6 thats in the SD's has a bigger imput shaft. I know the output shaft is bigger but I think the imput shaft is bigger too. just my .02
Franklin
Old Sep 20, 2007 | 11:16 AM
MikeFromShiloh
Thanks yall. A dude had a LUK solid flywheel cluthc kit on e-bay that was pulled from a 99 F550 It had been in the truck 3 months, he bought the truck and did not like it for some reason. I got on the LUK web site, we use the same flywheel which they had part numbers list for each but did not list the pressure plate or disc. I didnt think it would work but wanted to get some feedback here.
I was surfing e-aby and found this clutch. Anyway, my clutch went out which I replaced with factory duel mass junk. I did this before I found this web site. This is a GREAT WEB SIGHT !! Hind sight is 20/20.
thanks for everyones help MW
Stone1981F-150
Feb 22, 2020 11:14 AM
badkins5358
Jul 8, 2016 09:55 PM
51f2
Apr 24, 2016 05:37 PM
David Baerwald
May 16, 2013 10:44 AM
Hvymtlc5
Nov 4, 2005 01:40 PM
