Overheating
Old Sep 18, 2007 | 12:09 PM
mr240's Avatar
mr240
Overheating
I have a 02 4.8 Expy. Past couple of months I have been towing a Uhaul trailer with 2 motorcycles. Total weight probably around 1400lbs. I have notice that the temp gauge rises especially going up a big hill. Will a transmission cooler help with the overheating. Any recommendations.
Old Sep 20, 2007 | 01:08 PM
mr240's Avatar
mr240
Originally Posted by mr240
I have a 02 4.6 Expy. Past couple of months I have been towing a Uhaul trailer with 2 motorcycles. Total weight probably around 1400lbs. I have notice that the temp gauge rises especially going up a big hill. Will a transmission cooler help with the overheating. Any recommendations.
Any suggestions.
Old Sep 20, 2007 | 09:43 PM
ArgoExpedition's Avatar
ArgoExpedition
In a nut shell, No the tranny cooler will not help with a motor overheating problem; that would only help the tranny to keep cooler.
Actually we would need a little more information about things to help with any suggestions. I would suspect with the information you provided that all is working the way it is supposed to. Generally a system will get hotter as you are pulling a hill with any vehicle, especially if you are towing; and Im assuming that the guage does not peg at the hot range and that it returns to "normal" after the hill.
If you suspect that there is a problem, start checking the cooling system. Make sure the radiator is clear of debris, replace the thermostat, check the hoses and connections are tight, check for the right level of fluid, listen for the fan and make sure it is comming on.
Good Luck
Steve
Old Sep 21, 2007 | 09:00 AM
mr240's Avatar
mr240
I don't know if the temp gauge stops at a point when I am towing up a big hill. Once I see it moving, I turn on the heater.
Kregj
Jun 6, 2014 05:37 AM
oldtruck56721
Flathead V8 & Flathead 6
20
May 29, 2010 03:55 PM
Hmann
Sep 29, 2009 08:06 PM
Sean351
Mar 23, 2004 07:30 AM
Mar 11, 2001 10:13 PM
