when buying a short block..... you should?
Hey there FE fans I have a chance to pick up a 390 short block that its sealed never been started, the block has been bored .020 i don't know if it was decked or not yet, waiting for the reply. He knows its a semi aggressive cam, but the paperwork has been misplaced, there is paperwork on it being balanced tho.
Cam can be defined/degreed with a little effort but not likely to happen on sale day. Curious what color the pan is... I sold a 390 SB about 6 mo ago, located in so cal OC, black block 65', gold oil pan. Don't recall giving them the balance specs but may have CRS. If bal specs are from R&R Machine in Costa Mesa, I know the rest..
All of the above but also... If they allow you, remove the oil pan and look for play in the rod bearings. As you rotate the assembly, make sure everything is smooth and all pistons come up the same height; checking for bent rods. Also look for wear in the cylinder walls and such. If it wasnt machined or at least honed then there are questions. There shouldnt be a lip at the top of the cylinder; it may have been honed when it should have been machined. A lot can be said about details like freeze plugs and such as well. If its not like new... Any little thing... The price goes down.
If they don't give you the oppurtunity to check it out to your satisfaction, I'd walk away. Ask questions just to see how forthcoming they are with responses or info. If they fiddle around with your questions before they answer, it's a good chance theyt are hiding something. Crank and block are the most important items, the others can be replaced fairly cheaply but you probably don't want to go there either.
Monsterford34
09-29-2013 09:40 PM
djcapron
05-06-2010 09:59 AM
bigern6697
12-09-2003 11:26 PM
briandd1
08-05-2001 12:20 AM
