E4OD Leaking
Old Sep 17, 2007 | 01:11 AM
va150's Avatar
va150
E4OD Leaking
I have a 1990 F-150 4 wheel drive with a 4.9 and E4OD tranny. I bought the truck new but have not drove it much in the last 8 years or so. About a year ago I was hauling a heavy load up some hills on the highway and stoped for a break and noticed the transmission was leaking fluid bad. I let it cool down and put some fluid back in and it ran fine the rest of the way home. When I say it ran fine, it was running fine the whole way it just stoped leaking fluid after cooling down. Like I said I haven't drove it much in the last year but it does leak a little fluid now sitting in the garage. It seems to drive and shift fine. I am planning on driving it more now that my daughter has her drivers license, she will be driving my commuter car. The first question is does anyone think I damaged the transmission. Should I take it in right away to a transmission shop before starting to drive it again every day and any ideas what a transmission shop would charge to fix it.
Old Sep 17, 2007 | 01:20 AM
va150's Avatar
va150
Another question, the truck has 175,000 miles on it, if it is the front seal leaking should I have the transmission shop do anything else to it while they are working on it and how much money am I looking at?
Old Sep 17, 2007 | 10:43 AM
stuart1's Avatar
stuart1
It could have overheated and puked some fluid out.
At that mileage seals can be worn out.
You should also consider an external cooler.
VikingBabe
Sep 15, 2009 12:33 AM
Bjarni_Richter
May 10, 2007 03:54 AM
ZonaNavyStar
Sep 14, 2005 02:00 PM
racingdeathwish
Dec 19, 2003 10:23 AM
madman666
Nov 21, 2001 10:23 PM
