Sponsored by: Real Truck
4x4 problem
Old Sep 16, 2007 | 02:50 PM
900rr's Avatar
900rr
4x4 problem
i have a 2000 f250 4x4 crew cab v10 love the truck . here is my question my 4x4 stopped working when i turn the switch to 4 high or 4 low nothing on the dash comes up there is no engagement on the front shaft to the front diff the axle lock when in manual just at the hubs but nothing else any help please thanks and truck on
Old Sep 16, 2007 | 03:30 PM
biz4two's Avatar
biz4two
Arrow
Has got to be at the transfer case. On ESOF systems there is a transfer case servo-motor that shifts between 2Hi, 4Hi or 4Lo. First...I would check the connection, then check if power is present. If both checkout ok, then it is the motor itself.
Good luck with the fix...
biz
Old Sep 16, 2007 | 04:04 PM
900rr's Avatar
900rr
what is the process in checking for power at the motor and which one is the motor the big selonoid looking one or the one on the side of the tarnsfer case the connections all look ok
Old Sep 16, 2007 | 05:42 PM
kbeefy's Avatar
kbeefy
check your fuse also. don't remember which one it is but I think your manual points it out.
Old Sep 16, 2007 | 05:54 PM
hydro_37's Avatar
hydro_37
A test light is the best way to check for power. Put the switch to 4X4 and check for power going in the motor.
Old Sep 16, 2007 | 06:36 PM
EaTmYtAiLpIpEs's Avatar
EaTmYtAiLpIpEs
if its esof i can guarantee its the trasfer case motor. same thing happend with mine
Old Sep 16, 2007 | 07:30 PM
900rr's Avatar
900rr
fuses all looked ok and it is the esof and which one is the motor the small one on the side or the big black one on the bottom if the transfer case thanks for any help
Old Sep 16, 2007 | 07:36 PM
EaTmYtAiLpIpEs
its gray with a big black thing on it with 2 wires hooked to it. My hubs were toasted and the motor was no good. So I had the hubs replaced with warn ones which are in my gallery. And had an oem motor put on and it works all the time now. and i tired numerous times to check the motor to see if it was good and I thought it was. I hooked the jump it to it and turned it to see if it turned and it did. the motor isnt a hard job actually it is quit easy.
Old Sep 17, 2007 | 07:56 PM
900rr's Avatar
900rr
wheni take this part off what will i encounter will i need to add fluid will there be any parts that will be falling out or is it just straight forward
Old Sep 18, 2007 | 06:19 AM
EaTmYtAiLpIpEs
just straight foward. just unhook the wires. and take the bolts out. there is a lil shaft in there that is in the transfer case that slips right into the motor. nothing should fall out.
Old Sep 18, 2007 | 03:05 PM
900rr's Avatar
900rr
ok so i tested the wires on the truck the two wires going to the smotor has no power when the switch is in 2wd or 4wd with the truck running but the wires going to the six prong connector has power to all of them i checked the relay and they made no difference i checked the fuses and they were all fine now what do i look for any help please
Old Sep 18, 2007 | 03:19 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Does your ac go to the defrost mode when you turn it on? If it does then you have a vacuum leak.
Old Sep 18, 2007 | 03:22 PM
900rr's Avatar
900rr
no it does nothing no noise no front shaft engagement nothing at all
Old Sep 18, 2007 | 04:37 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
The other "thing" on the transfer case besides the motor is a sensor of sorts - it's really just a switch that tells the GEM what gear the transfer case is in, and which light to light .
There are also two relays for the ESOF system, if I recall correctly.
Old Sep 18, 2007 | 05:05 PM
900rr's Avatar
900rr
i switched the relay and still nothing they are up by the drivers side fender but i seem to have no power to the motor it self any help
