Hey Guy's , I've got to change the key switch in my buddies truck, Anyone have any idea on how to deactivate the airbag so it don't deploy while I'm removing the steering wheel ?
you do not remove the steering wheel to remove the key switch.
disconnect the battery, move the key to run, insert 1/8" drill in hole below the switcvh, push button with drill remove, install, turn key off, batt. reconnect.
