Shut down when switching Bullydog chip
Old Sep 14, 2007 | 10:27 PM
Skytim's Avatar
Skytim
Cool Shut down when switching Bullydog chip
Hey Gang,
My daughter and buds put in a Bullydog chip and when it was switched to the #3 position while driving the motor shut off and will not restart. Chip was removed, but still no luck. It cranks and the tach bumps up, but no start.
A friend put an analyzer on it and found a CMP nonfunction error, but I thought that would cause the Tach to stay quiet when cranking. I've checked the fuses and can't find any problem.
Any other ideas? Should I just buy a new CMP and try it?
Thanks
Old Sep 15, 2007 | 03:57 AM
Skandocious's Avatar
Skandocious
We're going to need a bit more info about the truck. With a cam position sensor I take it this is a diesel?
Have you tried resetting the computer by pulling the neg battery cable for a while. As long as you didn't fry any circuits/sensors this should put all your sensors back to learning mode and make the truck learn how to run all over again. As you might expect it might run a little strange for the first 15-20 minutes after resetting it.
The important question is, what was that #3 position supposed to do? (Mechanically that is). I know on my brothers diesel his chip modifies the computer program to dump more fuel into the cylinders when in the Xtreme position. It would be easier to diagnose the problem if we knew what the chip was trying to do to the engine.
Old Sep 15, 2007 | 02:48 PM
Skytim's Avatar
Skytim
Thanks, its a 1996 F350 7.3l turbo. I don't know what the chip is doing in the 3rd position. Haven't seen a manual on the thing. I'll try disconnecting the battery cable and will see if I can obtain the manual from my kid.
Old Sep 24, 2007 | 12:44 PM
BULLY DOG-JASON's Avatar
BULLY DOG-JASON
hey skytim pm me and i will figure out what happened to you truck and what I need to do to get it fixed
PAUL351W
Jan 29, 2008 10:26 PM
StevensPoint
Apr 19, 2005 08:56 AM
bobreid
Jan 29, 2005 05:23 PM
PAN
Nov 22, 2004 05:31 PM
majorpecs
Computer Chips & Tuners
Mar 8, 2004 03:39 PM
